Hey guys,
I have a R33 and its sitting on 18" rims at the moment, and its been lowered already, however problem is already is that the strut in the front is like liturally 2cms off the wheels (and its not even that low) how can i lower it more, without this hitting the rubber??
Also, who does complete custom jobs in lowering (or who knows of some type of springs that will put the rear wheels in the arch)
Thanks guys
Dayne
https://www.sau.com.au/forums/topic/69804-slamming-your-ride/
Hey guys,
Thanks guys
Dayne
You're car is already basically on the rubber, yet you want to lower it more? If anything, I'd be considering raising it to stock height to make it practical. I know it looks way better, but it's pretty much inevitable that you'll have more problems the lower you go.
hey fellas. He asked for advice on lowering it. not raising it. plus the bottom strut doesnt move. so 2cm is fine. it is no where near "basically on the rubber". and no its not a go-kart or a snow plow, its a skyline, a sports car, and some of might know that lowering a car's centre of gravity can increase handling potential. who said it was to look "full sik"?
Go the fully adjustable coilover option. That should get you the look your after. I had Apexi coilovers in my car, lowest point was 50mm off the ground, with the tires just tucking under the guards.
Do a coilover search; there are plenty of different brand options.
my rubber is about a cm or so away from the strut
but its a couple or so from the fender
Im about to try and put a set of king springs, super lows that have been cut even lower on, see how we go... i only have 17's on my car, i think i have a ways to go yet before im scraping bigtime :D
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
