Hey guys,
I have a R33 and its sitting on 18" rims at the moment, and its been lowered already, however problem is already is that the strut in the front is like liturally 2cms off the wheels (and its not even that low) how can i lower it more, without this hitting the rubber??
Also, who does complete custom jobs in lowering (or who knows of some type of springs that will put the rear wheels in the arch)
Thanks guys
Dayne
https://www.sau.com.au/forums/topic/69804-slamming-your-ride/
Hey guys,
Thanks guys
Dayne
You're car is already basically on the rubber, yet you want to lower it more? If anything, I'd be considering raising it to stock height to make it practical. I know it looks way better, but it's pretty much inevitable that you'll have more problems the lower you go.
hey fellas. He asked for advice on lowering it. not raising it. plus the bottom strut doesnt move. so 2cm is fine. it is no where near "basically on the rubber". and no its not a go-kart or a snow plow, its a skyline, a sports car, and some of might know that lowering a car's centre of gravity can increase handling potential. who said it was to look "full sik"?
Go the fully adjustable coilover option. That should get you the look your after. I had Apexi coilovers in my car, lowest point was 50mm off the ground, with the tires just tucking under the guards.
Do a coilover search; there are plenty of different brand options.
my rubber is about a cm or so away from the strut
but its a couple or so from the fender
Im about to try and put a set of king springs, super lows that have been cut even lower on, see how we go... i only have 17's on my car, i think i have a ways to go yet before im scraping bigtime :D
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
