Howdy all.
I ran my Stagea at the local drags last weekend for a bit of fun. The best time I could do was a 16.72 at 130 clicks I think. My slowest was a 16.88 so I was pretty consistent. My reaction times were .5s and .6s.
My question is.
What should I do to my wagon to really get her hopping without losing and preferrably gaining some reliability?
I already have a full 3" exhaust, rampod and an SAFCII my Profec B Spec II should be here next week. I should also have a front mount and a bigger transmission cooler by the next meet, also a carbon box for my rampod.
Is there anything else I should consider?
Id love to get the valve body upgrade installed. If I bought one could I install it myself?
Oh and would it be safe to have my car running 11psi for the whole run? Should I start at a lower setting and then switch it up?
I think thats all I wanted to know.
Any help would be fantastic.
Thanks guys.
Zane.
https://www.sau.com.au/forums/topic/69809-dragin-the-wagon/
My 10 cents (race meeting this weekend, have to move it)
I have been using 10 psi for quite a while now, I can get 7 psi at max stall on the standard torque converter (around 2,300 rpm) holding it against the hand brake and the foot brake. I don't worry about reaction times, it has no effect on your ET.
Note that I have zero mechanical mods, just the IEBC and the DFA. The exhaust and intercooler upgrades will make a big difference.
How were you launching yours?
https://www.sau.com.au/forums/topic/69809-dragin-the-wagon/#findComment-1291134
Went to Adelaide International Raceway last night and did two passes. I managed a 15.2 and then a 15.0 at 91.3 mph. On my second run I went up against a Subaru Legacy GT with similar mods to mine, (full 3" exhaust, R34 GTR intercooler, 10psi, exh. cam gear, air filter, s-afc II). He ran a 15.5 but still won due to a much better reaction time.
It was all a bit of a learning experience for me, so I'm hoping that with some practice, a little weight reduction and a slightly better tune, a high 14 will be achievable.
Cheers
https://www.sau.com.au/forums/topic/69809-dragin-the-wagon/#findComment-1303946
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
