Howdy all.
I ran my Stagea at the local drags last weekend for a bit of fun. The best time I could do was a 16.72 at 130 clicks I think. My slowest was a 16.88 so I was pretty consistent. My reaction times were .5s and .6s.
My question is.
What should I do to my wagon to really get her hopping without losing and preferrably gaining some reliability?
I already have a full 3" exhaust, rampod and an SAFCII my Profec B Spec II should be here next week. I should also have a front mount and a bigger transmission cooler by the next meet, also a carbon box for my rampod.
Is there anything else I should consider?
Id love to get the valve body upgrade installed. If I bought one could I install it myself?
Oh and would it be safe to have my car running 11psi for the whole run? Should I start at a lower setting and then switch it up?
I think thats all I wanted to know.
Any help would be fantastic.
Thanks guys.
Zane.
https://www.sau.com.au/forums/topic/69809-dragin-the-wagon/
My 10 cents (race meeting this weekend, have to move it)
I have been using 10 psi for quite a while now, I can get 7 psi at max stall on the standard torque converter (around 2,300 rpm) holding it against the hand brake and the foot brake. I don't worry about reaction times, it has no effect on your ET.
Note that I have zero mechanical mods, just the IEBC and the DFA. The exhaust and intercooler upgrades will make a big difference.
How were you launching yours?
https://www.sau.com.au/forums/topic/69809-dragin-the-wagon/#findComment-1291134
Went to Adelaide International Raceway last night and did two passes. I managed a 15.2 and then a 15.0 at 91.3 mph. On my second run I went up against a Subaru Legacy GT with similar mods to mine, (full 3" exhaust, R34 GTR intercooler, 10psi, exh. cam gear, air filter, s-afc II). He ran a 15.5 but still won due to a much better reaction time.
It was all a bit of a learning experience for me, so I'm hoping that with some practice, a little weight reduction and a slightly better tune, a high 14 will be achievable.
Cheers
https://www.sau.com.au/forums/topic/69809-dragin-the-wagon/#findComment-1303946
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
