  • Replies 78
u.g.l.y
I'd rather keep the dash and center console and keep the 10-20kg :)
amen. especially if the car is running 14s I'd suggest the time be better spent anywhere other than on ripping bits out.
True however i'd rather spend money on light wheels, lighter drivetrain components, lighter panels, less fuel, remove aircon, hicas etc etc than rip out the front dashboard with the bloody gauges sitting in the middle looking like the car was just ripped off from parra westfields.
Maybe if it was a 10.5sec car trying to break into the 9's, but hell if its still mucking around in the 14's effort could be put elsewhere...
Rocco's car looks like it was stripped in a bit of a rush as the cluster and centre gauges where just cable tied to the dash cross bar. Rocco's isn't a novice, I'm sure he will get that car moving once sorted.
no it was defently a destroke he was thinking of doing. my car is in being rebuildt by them now we where talking about on the weekend and the turbo is from that ff guy hows turbos keep f@#kn up when boosted.
Straight from a horse's mouth (or taking a page from SST Steve)...
Rocco didn't get the time to change the injectors on the R32 - it still had the standard ones in it. It's got some huge Turbonetics turbo on it, and should be running better at the next meeting.
Video I took of twoogle running a 12.28@130:
http://www.rxmazda.com/TWO26L_12.28.AVI
Another of it in eliminations against a white datto 1200:
http://www.rxmazda.com/R32GTR_V_WHITE_DATTO.AVI
2RISMO versus the silver 1200 from rotamotive:
http://www.rxmazda.com/2RISMO_V_silver_1200.AVI
Guest two.06l
http://www.rxmazda.com/TWO26L_V_white_datto.AVI
never ran a white datto, must have been dave...the other DIRTgarage car (orange indicators)...thanks for posting my worst run of the day...got any decent ones...eg 11.2-11.3
Ahh ok, thanks for the correction - i'll change the file name. It was late in the night when I was sorting the 40 videos out. I got one of you staging as the other car took too long and the video capture on the digicam is only 30 secs long. So only got the back end of the run. I will upload it anyway. Sorry, but they were the only runs I managed to film - I had to juggle 2 young nephews and a niece, plus two cameras, and a neverending food supply. But I thoroughly enjoyed the day. :D
Corrected link. Also uploaded only two videos I have of the twoogle mobile:
staging games with NOSPIG:
http://www.rxmazda.com/TWO26L_NOSPIG_STAGE.AVI
and end of that run - 11.3@130:
http://www.rxmazda.com/TWO26L_11.3.AVI
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
