OK, result is in guys. I ran a 12,466@108,20mph with 1,860foot time on TEIN RA, street tyres that wore out ( Phillip Island track day ), Heavy duty clutch.
I did the 12,4 pass with second gear bog down so in my third attemp, i dumped it at 7,5k. There was no bog down, as i slamed it into 2nd, rev was still at 6k which is good where when it bog down before it went to 4,3k, car make noise but didnt go anywhere i then realise the freaking clutch is slipping.
Next time i'll go out try to dip it into the flat 12 or hopefully high 11 with proper GTR rims ( as i still running on 235 front and 265 back ), good tyres, clutch and see how i go. I belive my transfer case still confuse even down the end of the terminal as i look at the tougre gauge i had around 30% power to the front where it should NOT. It should have 100% to rear.
Anyway i only own my gtr for 2,3 months so there is a lot to learn about it but i'm can tell u now i love the launch on the GTR. ****ing awesome.
  • Replies 96
West, 30% is what it should read giving it full throttle.
i know my mates GTR reads like 30% while hes going full throttle 180km/h+if he launches hard
Like said i'm still have a lot to learn about the GTR, i thought it suppose to give 100% to the rear after it gained traction so u can have more power but anyway its all good.
Forgot to mention i only run 14psi. :P
Nice! ;)
I want to buy a GTR R32 soon.. but i mite stick with my sil80 i just bought :P
']someone correct me if i'm wrong on this...but dont GTR's work based on lateral G forces and not based on traction?
they work on both g forces and traction. sensors detect if rear wheels are rotating faster than front and feed power into front accordingly. thats why gtr's need wheel sizes exactly the same otherwise power will be fed into front wheels cause computer thinks wheels are slipping
You can have thinner tyres on the front.. but you cant have differnt size wheels and profile tyres.
You can have thinner, different wheel size and different profile, the thing that matters is the rotating diamiter has to be exactly the same, otherwise the ATTESA will think the wheels are slipping and apply torque to the front. The best way to get exactly the same rotating diamiter is to have the exact same size wheel/tyres on the car..
West: Well don on the 12.4! Thats the same as i ran when i went to the drags, but i was running @112mph i think... but i couldn't get off the line, axle tramp everywhere.
thats what i said about the tyres man :cheers:..
The GTR race team that was eventually banned from racing way back when had an interesting method for getting off the line. They had a delay switch fitted to the front wheel drive so that the rear wheels would spin and let the engine get to it's 6000rpm with the drive train 100% locked in. Then the ATTESA would kick in and load up the front.
With this method there is no wear on the clutch and the drive train had an easy start. I would imagine the transfer-box would heat up a bit, hence, the transfer case cooler.
You said "...but you cant have differnt size wheels and profile tyres."
You can have different sized wheels and profile tyres if you like, but the rolling diam needs to be the same.
but if you change the tyre profiles then you will change the rolling diameter :confused:
profile depends on the width of the tyre. Also you could have a difference sized wheel, which means you'd need a bigger profile etc....
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
