  • Replies 159
Darren we paid $150 for our headgasket.
Be sure to follow the manufactures install instructions. :cheers:
They make them to suit the RB26 (same as RB30) and also the R33 RB25DET with its VCT.
The RB26 headgasket is a little more expensive than the RB25DET gasket.
You can use the RB25DET gasket on the RB30DET with no drama's.
I thought it was $150, but didnt want to quote it just incase i got it wrong...but there you go :rant: I thought Andrew (our machinist) told me it was the rb25 gasket he used as well.
Well i heard stock internals on an RB20 wit the right tuning etc can handle 18+psi, but i wouldnt go past 15psi on an rb25 due to the higher compression levels! Even though its only 2psi more should give you a shitload more power as you'd get closer to the turbos efficent power range im guessing.
just had the head pulled of my rb25,and there is nothing wrong with the stock nissan headgasket, but my engine has engested a small piece of metal!! probably left over from the dodgy welding done on the inside of my custom 4inch air take. motor needs a rebuild. so running 20psi bost wasnt what killed my engine it was foreign material.
you didnt check it before putting it on?
i'd check for dmg on the turb too, would be if its from before a turbo.
oh btw, ran up 369rwkw @ MAS yesterday.
will get my dyno sheet and more details when i have some time/scanner & someone to host it lol.
how much did it cost to rebuild your engine r31 nismoid? whats been done? who rebuilt it?
around the 7k mark, motor in and out included.
GTR Rods, Forged pistons, tuned etc etc.
Done by Ben @ Race Pace Motorsport, i wouldnt take my car anywhere else :(
What fuel and psi was that with?
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
