And you can't break traction in first gear, wtf? :wassup:
when i had 330rwkw i could :(
Denham, it was running 24 psi on 104 octane fuel.
There is a slight turbo issue with my car in that its slightly mis-matched and has a bit of surge down below, and much over 17-18psi it gets some detonation.
Not much i can do, but give it some good fuel and its a open slat. We didnt wind more boost in as i need some ignition.
thats next on the list if i want some more power on 104
  • Replies 159
when i had 330rwkw i could  ;)
Sunocorp 104 straight or % mixed in with 98??
If will start getting expensive if you have to run 104 for daily use :(
U have standard cams, head etc dont ya?
pure 104, had to be to get over the detonation problems on PULP due to the turbo
im not using it daily like that. lol. Im dropping back to under 300rwkw for normal driving. 330-360rwkw is useless.
We were seeing what we could do with the car for salon by have a play around with some things.
We found some more limitations on the hardware i have. We'll stuff more than 24psi into it once i get my ingition sorted (which is a long way away)
Race Pace Motorsport, the one and only place ill take my car from now on.
There is no-one decent around the west/north. I've been through many workshops who just have muppets working there who dont know enough to satisfy me taking my business there.
Race Pace is about a 45mins drive... to bayswater. But my car has been going there since mid last year.
Very thankful. Its worth the drive.
does anyone know what part number or serial number is stamped into a genuine gtr conrod? are all gtr rods created equal?
Sorry, my conrods went in 2 weeks ago - can't check for you. As far as I know, the R32 & R33 GTR conrods are the same size & strength. I can't give you a definite answer, as I was only told by a couple of engineers & 2 different sellers on the forums (can't remember their names), when I bought mine. I used R33 GTR conrods in my R33 GTS-T. Not sure about R34 GTR conrods.
Someone should soon post a 100% yes or no answer for you, I'm sure.
Cheers
Chris
can anyone recommend any good engine rebuilding workshops in or around epping victoria??? r31 nismoid youre from around this area, any ideas?
P.E.T Modifications are in thomastown and have built plenty of tough and big hp Nissan engines (VLs, Skylines, GTRs, etc).
Give dennis a call on 9464 4225 and tell him Gorjan (RS500) referred you.
they should be all the same from memory.
Put em next to an RB25DET rod and you can instantly see the difference.
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
