And you can't break traction in first gear, wtf? :wassup:
when i had 330rwkw i could :(
Denham, it was running 24 psi on 104 octane fuel.
There is a slight turbo issue with my car in that its slightly mis-matched and has a bit of surge down below, and much over 17-18psi it gets some detonation.
Not much i can do, but give it some good fuel and its a open slat. We didnt wind more boost in as i need some ignition.
thats next on the list if i want some more power on 104
  • Replies 159
when i had 330rwkw i could  ;)
Sunocorp 104 straight or % mixed in with 98??
If will start getting expensive if you have to run 104 for daily use :(
U have standard cams, head etc dont ya?
pure 104, had to be to get over the detonation problems on PULP due to the turbo
im not using it daily like that. lol. Im dropping back to under 300rwkw for normal driving. 330-360rwkw is useless.
We were seeing what we could do with the car for salon by have a play around with some things.
We found some more limitations on the hardware i have. We'll stuff more than 24psi into it once i get my ingition sorted (which is a long way away)
Race Pace Motorsport, the one and only place ill take my car from now on.
There is no-one decent around the west/north. I've been through many workshops who just have muppets working there who dont know enough to satisfy me taking my business there.
Race Pace is about a 45mins drive... to bayswater. But my car has been going there since mid last year.
Very thankful. Its worth the drive.
does anyone know what part number or serial number is stamped into a genuine gtr conrod? are all gtr rods created equal?
Sorry, my conrods went in 2 weeks ago - can't check for you. As far as I know, the R32 & R33 GTR conrods are the same size & strength. I can't give you a definite answer, as I was only told by a couple of engineers & 2 different sellers on the forums (can't remember their names), when I bought mine. I used R33 GTR conrods in my R33 GTS-T. Not sure about R34 GTR conrods.
Someone should soon post a 100% yes or no answer for you, I'm sure.
Cheers
Chris
can anyone recommend any good engine rebuilding workshops in or around epping victoria??? r31 nismoid youre from around this area, any ideas?
P.E.T Modifications are in thomastown and have built plenty of tough and big hp Nissan engines (VLs, Skylines, GTRs, etc).
Give dennis a call on 9464 4225 and tell him Gorjan (RS500) referred you.
they should be all the same from memory.
Put em next to an RB25DET rod and you can instantly see the difference.
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
