  • Replies 159
some very differnt powers being made with similar turbos. my rb25 with a gt30 .82 and external gate made 420rwhp @ 27psi
ive added a pic of the dyno sheet, the red line is my first engine with aria pistons and higher compression, the blue line is the same head, less compression and wiseco pistons... I had hi flowed injectors, pump, micro tech etc etc...
some of you guys have made good power on such little boost... have any of you gone down the track??
with 300rwhp i ran 13flat @ 114mph
Track I am refering to is Sandown and Phillip Island were i found i had to modify my driving a fair bit so that when i powered out of the corners I could keep the engine in the power curve of the rev range. Sometimes it was a comprimise between using 2nd gear and wheel spinning out of the corner and loosing time or staying in 3rd and having the car bog down for a while till the needle went near 4000rpm.
That is one hell of an interesting dyno graph RNS11Z. It is not often you get the chance to compare the same engine with different compression ratios. Can you notice the 50rwhp less at ~4,600 rpm? Or does it go through the 4,000 rpm to 5,2500 rpm band so fast you don't feel it? I notice that the current set up has ~1.5 psi more boost at 5,150 rpm, is that deliberate? Or did you have to run less boost with the higher compression?
Lots of things to think about on that dyno graph, for a data not like me anyway.:D
I was having problems with the external gate which is why it wouldnt hit target boost straight away on the first engine. When building the 2nd engine we fixed the gate, as you can see it spiked 1-2psi then settled.
The 2nd engine was much more smoother too drive and felt better on the st. The first engine was real snappy.
Peak power on the first engine was 421.??
i think it would be a tad too big, but it all depends on whay you dont mind living with for the extra power. abo bob has got my power graph, when he posts it up for me you guys can have a look how a gt30 with .63 exhaust makes power on an rb25 with stock compression.
wonder how the GT30 with the .63 would go on a rb20 ;) seeing as the rb20 has stuff all puff
i just might have to try it :)
give me about 2 weeks and my rb20 will be in my s14......
its currently got a gt30r with a .63 ar bolted to a hks manifold with the gate set at 14psi/1bar.
i also threw in tomei procams (260/8.8mm lift intake/exhaust) to help it along and some greddy gears.
currently the fuel rail is loaded with some 550's and gonna burn a custom chip to change redline as well as control the larger squirters.
will be using a emanage to tune with a tech edge wideband.......
should go quitenicely......
oh and some one on here said they used a gt30 with a .86 ar on an rb20 and they got 14psi at around 4k.
I wouldnt question the exhaust.
I'd be looking at the ECU/tuner.
One assumes its aftermarket of course... and there is a very big hole in the power band that should not be there at all.
With the smaller housing it should ramp onto boost easiler also. Which i'd put down too the tuneings fault again
That car for the turbo has a smaller powerband than mine with the bigger housing which in thoery should be a bit laggier
Carl... i'll take you for a burn in mine next week if you want and show you how mine goes with a decent tune :)
Hmm, I found a few things that made mine come onto boost alot harder, and hold better to redline - one of them was exhaust being very restrictive. It wasnt a problem until I got the larger turbo on - just choked it as I turned up the boost. Easy way to tell, just drop the exhaust for a quick run around the block :) or on the dyno if your not feeling adventurous.
Second was a flange leak from the manifold to the ext wastegate - only a small one, not audible by ear, needed a stethescope type device - but made a big difference, boost earlier and far more responsive.
Last one was BOV leaking at higher rpm.
Some ideas anyway, hope they help
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
