Sorry if you thought I was implying you werent making the power - 270kw isnt enough to really start doubting people about unless of course its in a Hyundai:)
out of interest (means alot more than just peak power) what sort of power are you making at 3000rpm, 3500rpm, 4000rpm, ........ 7000rpm (or wherever you have redline) The spread of power speaks volumes about a cars performance.
Also, what wheel alignment specs are you running?
  • Replies 159
If you wanted OEM type performance , ie 4 - 6 pounds of boost no doubt a GT30R could do it . To do this you would probably need a rather large waste gate to prevent exhaust restriction . Always remember that when looking for higher boost levels (waste gate shut) marginally sized turbines can form a restriction for exhaust flow . With your example the 63ARR turbine housing is painfully small for a three litre blowing into a GT30 turbine . I try to look at what the manufacturers do - they have many millions to spend on R and D . I see the XR6T as a good example , the GT35R is perfect for a low performance (boost) four litre but note its housings choise . Its turbine housing is the largest of the three sizes available while the compressor cover is the smallest ratio (of three) and a family size down on what GT40 compressors generally use . I believe Ford was looking for absolute minimum exhaust restriction (large 1.06 ARR turbine housing) and not very high airflow rates to enhance a large capacity engine .
For most of us Nissan fans we're looking at three litres and a more sporting breed of transport ! The same principles apply though the variation's are less weight and a smaller airpump (donk) . If it were me I'd use the largest available turbine housing for that GT30R and the port shrouded .60 ARR comp cover they normally come with . Even this with a large gate and lowish boost is really only suitable for a low rev ceiling engine but thats good enough for some especially on the street .
Cheers A .
im running stock cams, 3inch exhaust , maybe they are restricting it a bit. because its pulling 229 rwkws at 13psi and only another 31 rwkws at 20psi???
bigcarl,
i believe that when a turbo is in it's highest efficiency island and that there is no exhaust restriction, the power increase per psi should be about ~10rwhp (7rwkw), so you should be making a bit more power on 20psi.
which GT30 core is it and what exhaust housing r u running?
500hp compressor. a/r70 comp front cover and a/r 64 rear housing. good info thanx rs500. just found out today the max boost the standard nissan head gasket can take, ive blown my head gasket running 20 psi/ 22psi. does anyone know where and how much i can pick up a tomei after markey head gasket for??? would lowering the compression ratio help make my engine last a little longer before rebuilding?
Not sure about tomei, but if you check the greenline site, I believe it give detail of CR
I had a HKS 1.6mm, gave a 8.6:1 CR. I did this because I was advised by a jap that it was best when pushing the stock internal RB to around 300rwkw and a bit beyond. According to him (and other sources) it is not uncommon to make 300+ with stock internals in Japan as long as you decompress. JMS also did this with their GTSt, and it lasted well even with Denzo thrashing it :)
Also, this jap guy recommended keeping boost around 1.2bar for hard thrashing on the track, but said it was ok to run 1.7+ for drag or dyno, just not prolonged caining. (tune permitting of course :()
make of it what you will, but my engine has survived without rebuild.
1. does anyone know how thick the stock headgasket is?
2. what comp ratios does tomei head gaskets 1.2mm
3. 1.5mm give on a standard engine?
1. 1.0 mm
2. 8.8 to 1
3. 8.5 to 1
Combustion chamber volumes do vary, so treat the above as a guide only.:D
why spend $600 on a Tomei head gasket when you can get a very similar multi layer composite metal head gasket from Cometec for a fraction of the price
thats what I was told when building my engine...cant remember the price exaclty of the Cometic, but its a hell of a lot cheaper than the Jap brand gaskets around. Its a 3 layer metal head gasket with like an inbuilt o-ring setup. Apparently they use em on diesel engines, and in Group A?? dont know if its true or not....
i bought one of these for my rb30det and the price was around $300
no there is no need to o'ring the block with one of theese head gaskets. i have to see if i still have the part number, its an rb30 head gasket not rb25. i got it through the people that did the machine work to the block so not sure where they got it from.
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
