  • Replies 159
I think before the cams Steve's R33 made ~250rwkw on 1bar with the .69 exhaust a/r.
Twin 3037S on a GTR has made 700rwkw. Obviously big cams etc.
But still quite respectable power.
The you consider the HKS 2835's that make up to 280rwkw on the RB25's.
correct, obvious that a car has bolt ons if its making over 300rwkw. But it didnt have larger capacity engine (RB26 internals) or port work - just bolt ons.
oh, and Joel, it made just shy of 260rwkw with a restrictive exhaust at 1 bar with a 0.63AR turbine housing, before the cams - that was with a 20 odd minute Martin Donnin tune, he just did a rough tune to keep it going until it was sorted (other mods added)
Interestingly, it only made 270 odd at 1 bar with the cams, but the CR was lowered to 8.6 to 1
LOL...but the the 2835 owner will wind 1.4bar into the strd RB25 to see what it will do...and many of the gT30 owners seem to pull the pin when they get to 1bar and 250-260rwkws
Soft my ass!!! I wound in 1.4 bar from my GT30 when i ran the 320rwkw at the selectamz dyno day and last years autosalon dyno comp
remeber this is an Autosalon dyno result too...
Ash we need more info.. Was it also a DD dyno or another type?
I just find it a little hard to believe an RB25 with GT30 achieving 369rwkw :P
more will come when i can scan the graph, it was a mainline dyno.
i suspect around... 20rwkw higher at a rough stab as i have 330rwkw a day before in the all hailed shootout mode on a DD dyno
was that 330 on ben dyno? What psi were you running and what fuel?
Did you have head/valve/valve spring work done when the engine was getting rebuilt?
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
