gt 30 dyno results
And you can't break traction in first gear, wtf? :wassup:
when i had 330rwkw i could :(
Denham, it was running 24 psi on 104 octane fuel.
There is a slight turbo issue with my car in that its slightly mis-matched and has a bit of surge down below, and much over 17-18psi it gets some detonation.
Not much i can do, but give it some good fuel and its a open slat. We didnt wind more boost in as i need some ignition.
thats next on the list if i want some more power on 104
  • Replies 159
when i had 330rwkw i could  ;)
Sunocorp 104 straight or % mixed in with 98??
If will start getting expensive if you have to run 104 for daily use :(
U have standard cams, head etc dont ya?
pure 104, had to be to get over the detonation problems on PULP due to the turbo
im not using it daily like that. lol. Im dropping back to under 300rwkw for normal driving. 330-360rwkw is useless.
We were seeing what we could do with the car for salon by have a play around with some things.
We found some more limitations on the hardware i have. We'll stuff more than 24psi into it once i get my ingition sorted (which is a long way away)
Race Pace Motorsport, the one and only place ill take my car from now on.
There is no-one decent around the west/north. I've been through many workshops who just have muppets working there who dont know enough to satisfy me taking my business there.
Race Pace is about a 45mins drive... to bayswater. But my car has been going there since mid last year.
Very thankful. Its worth the drive.
does anyone know what part number or serial number is stamped into a genuine gtr conrod? are all gtr rods created equal?
Sorry, my conrods went in 2 weeks ago - can't check for you. As far as I know, the R32 & R33 GTR conrods are the same size & strength. I can't give you a definite answer, as I was only told by a couple of engineers & 2 different sellers on the forums (can't remember their names), when I bought mine. I used R33 GTR conrods in my R33 GTS-T. Not sure about R34 GTR conrods.
Someone should soon post a 100% yes or no answer for you, I'm sure.
Cheers
Chris
can anyone recommend any good engine rebuilding workshops in or around epping victoria??? r31 nismoid youre from around this area, any ideas?
P.E.T Modifications are in thomastown and have built plenty of tough and big hp Nissan engines (VLs, Skylines, GTRs, etc).
Give dennis a call on 9464 4225 and tell him Gorjan (RS500) referred you.
they should be all the same from memory.
Put em next to an RB25DET rod and you can instantly see the difference.
so just checking something, i am planning on using a gt30 with a .82 rear. I was hoping on around 17-18psi on a 1jz-gte i could make 280rwkw, with intercooler and a few other bolt on mods, is this possible? Thanks for your helps guys
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
