Hey
Im thinking of getting a Ipod and a fm transmitter to broadcast the ipod through my car speakers.
I have been looking at Roadtrip and Transpod which are the ones the transmit and charge ur ipod at the same time as well as hold it.
Could anyone tell me how good these are? or if there is a better way of playing the music through my car speakers with out a big hassel.
My factory head unit alredy has a line out for the factory cd stacker which I dont have (2 RCA cords and 1 stacker cord)
I anyone can let me know about these transmitters, clearness and quality etc or another way I would be greatful
Thanks
CHASP
https://www.sau.com.au/forums/topic/69840-ipod-fm-transmitter-help/
Im not too sure about the Roadtrip and the Transpond.
I have a Griffen Itrip which only transmits so it doesnt charge but when i use to use it i thought it was pretty good sound quality.
Just takes a bit of trial and error where to set the transmitter and where to actually have it placed in the car.
They are crap. Connect it to your deck or if you can't, get a better deck...
i agree ;)
i bought a Griffin itrip for my ipod mini, i took it back after a day, the sound qaulity was shithouse, it sounded shit on both my car deck and on my very $$$ sony sound system in my house.
My tip say away from them untill apple mades one :D
you can get belkin ones from jb hi-fi and the like that you can tune in to any station you like for about $70.
big w sell fm transmitters for $40 but they are locked to 4 stations, which it will swap from one to the other if it interferes with another station.
dont know what the quality is like of either one, but i plan on getting one for my Hi-MD
Guest Emperor
Yeah the signal is not very strong.  I'd get an RCA to 2.5mm stereo jack cord and hang it out the back into the passenger footwell.  Connect your ipod there.  You can just tuck the cord up behind the dash when not in use.
hey abo bob, this sounds like a good idea, do most aftermarket deck allow you to plug the RCA plug in (warning i am audio newbie), My friend has a similar setup in his car and the quality is very good (but his is connect to some cheap mp3 player :))
Thanks Emperor
no, the input on your amp is supposed be to connected to the output on your deck. the output on your amp goes to the speakers.
what you need is what is known as an "auxilary input". don't bother pulling your deck out. you can check this by simply hitting the 'source' button. it should go through 'CD', 'Tuner' and (if you have one) 'Aux' if you get that option you will no doubt have an RCA input on the back of your deck.
the belkin fm transmitters are crap i bought one and returned it after one day..
the signal was not strong enough for the cd player to get more than about 30 seconds before fuzzing out and in again.
it would probably be better if you did not live in a cbd area..
  • 3 weeks later...
I got a griffen fm transmitter and it's only ok. Maybe because of all the radio stations in Sydney but it's mission impossible trying to find the right band. And even still it's only ok. When I get my next car I'm gonna get an Alpine deck which can connect directly to my ipod.
my pioneer deck will only bring up the AUX if there is something connected to it.. same with the cd changer....
the new alpines have a direct line into the ipod and will show the id3 tags and stuff direct from the ipod unit, its some form of firewire link or something, someething alpine and apple worked on together
Pioneer have finally released an Ipod interface. It plugs into the cd stacker interface and gives you complete control over the Ipod using the controls on the head unit which also displays the tag info. I'd imagine JB Hifi and similar stores would have 'em in stock by now.
mike
  • 1 month later...
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
