I have searched and cant find anything ellaborative enough.
Please does someone know of a website that outlines the strength of nissan boxes, sizes and other impt specs and pros and cons of each box?
If you know, post your knowledge and maybe I can collate the info amd make a site.
Cheers
180 JT , there is an American site called Handy Dandy Denny with ya or some such , do a search . Its mainly Z stuff but lots on transmissions .
Basically the Nissan / Datsun gearboxes use a series number based on the number of mm between the main and layshaft centers . The series and options of the boxes is usually cast in the side of the case . The numbers and letters define the bellhousing type and bolt pattern , the shift mechanism , the shaft centers and possibly the syncro type . There are lots of variations that were model specific but the basics are as follows for the 71 series 6 cyl boxes .
240K - 71mm centers , servo (Porsche) syncros 1-4 , warner syncro 5th
narrow gears , steel forks , steel front bearing cover / spigot , wide ratio .
260Z - same as above with closer ratios ie 2.9 1st , aluminium front bearing cover .
910 - FS5W71B - same but unique ratios ie 3.32 , 2.07 , 1.31 , 1 , 0.83 , alloy
forks , all Warner syncros .
Z18T - LZ5W71B - as above but wide ratio ie 3.6 1st , Z/L bellhousing .
FJET - as above with Skyline ratios ie 3.32 , 1.906 , 1.31 , 1 , 0.83 . Wider
gears , larger diameter syncro hub 1-2 , larger diameter 1-2 shift rod , FJ
bellhousing .
RB20T - RB71C as above with larger 3-4 syncro hub , C type shift mechanism , all
large shift rods , larger front lay gear bearing (also used in Ser 3 bird) .
Sub gear on front of laygear to prevent backlash at idle in neutral .
As for the larger boxes used with VG30's , RB25T's , RB26's and
RB30ET's I'm not sure of the specific numbers . I believe the shift
mechanism is partly external on Z32's . I think the ratios are wider on the
VLT box than R33 25T and the VL box may not have the twin cone
syncro hubs .
Is it certain that the RB25DET is internally stronger than the RB20DET?
I know it is externally bigger, but can anyone confirm that internally the 25 is stronger than the 20.
Ive had bearing probs with mine, but so has my friend in his R33 with less power and less Km's.
So still tossing up wether its worth swaping for a RB25 box....
There is no question that an RB25DET gearbox is much stronger than an RB20DET gearbox. Everything - gears/shafts/bearings - is physically much bigger in the RB25DET gearbox.
None of the early gearboxes (up to the end of R30 production) have any (usable) identifying marks on the outside. The top of the bellhousing just behind the head sometimes has some stamped numbers/letters which might be a serial number, but only Nissan know
servo (Porsche) syncros 1-4 , warner syncro 5th.
Actually the otherway around - warner on 1-4 and servo on 5th, although have seen one or two with warner synchro on 5th. Only 240Z/260Z 5-speeds got servo synchros on gears 1 to 4
240K 5-speeds used the FS5W71B gearbox, but early cars were 4-speed (FS4W71A) and 3.5 diff ratio.
240Z/260Z used steel front cover, same as 240K. Early 240Z used FS5C71A g/box (flange output; similar to Fairlady gearbox) , late had FS5C71B same as 260Z.
its an import, you cant use odometer readings to judge anything.
Rb25 box should be just about unbreakable in an quick street driven r32 with an rb20.
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
