Hey everyone,
Can someone please tell me how I can fix a small problem with my car. I own a R32 4 door (rb20det) as I drive along my car will start dieing, the revs will drop and sometimes it will stall or suddenly pick up again. Sometimes it will stall and will not start after about 10 mins of trying, I have changed the air flow meter twice. I could go ahead and take my car to tokyo toys in which they forward the car onto a place down the coast which do a dyno read outs and hopefully find failures in my engine, but for it to do that my car needs to be broken down which most of the time it does not do.
I live in brisbane and was wondering if anyone could help me
thanks guys
https://www.sau.com.au/forums/topic/6994-need-help/
Sik32,
The revs dying then picking up again sounds like it may be a fuel issue. When you say that sometimes you can't start the car for 10 mins, can you be more specific. Is it flooding or not enought voltage to cause a proper spark?
There are a number of things it could be, AFM is just one of them, but having replaced it twice it seems unlikely. The coilpacks on the RB series can start to play up when they get hot, and wont provide sufficient spark for combustion.
If you provide us with more details we will try and narrow your search down.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-103399
To GTS-t VSPEC,
Thanks for the reply, when i drive along and the engine dies then I pull over and turn the igniton to start the car. It just windes over , I wait 10 -15 mins then it starts. Sumtimes it will start straight away whilst still rolling.
Also as i drive along a highway the engine nearly dies I hold down the accelerator and then it just picks back up and goes like normal.
Good luck ,
ps. Im getting a datastream print out for it on monday do u think this might find this intimiting problem
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104169
Sik32,
Its difficult to tell with an intermitant problem such as this, I would be leaning towards faulty coilpacks as the problem. The would cause a miss which could cause the revs to drop and stall the car. This is can be related to the engine being hot, hence the reason its intermitant.
It might be worth taking the coil-pack cover off and having a look at both your coilpacks and sparkplugs, if something is wrong then you might have a burn spot around the coilpack cover, or one sparkplug might have a burnt appearance.
I take it you haven't noticed it missing whilst driving or difficult to start in the morning? Do you have any fuel management running?
I hope we can start to narrow this down further, but start looking there as it won't cost you anything if you do it yourself.
See'ya :burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104330
Guest Boxhead
im not sure if this will help or not..
but.. when i was driving my na behind dave and another guy, a mini cruise, they were going medium, so basically to keep in eyes distance, i had to go flat out..
we pulled over somewhere.. leavin car runnin, just to get out and decide were we are going, which way etc, we decide, i go back to my car, and suprisingly engine is off.. i try to start it.. and it wont start, starter motor is workin, can hear that etc, but engine wont kick over, however... the heat gauge is showing in the middle(as per usual..) you must keep in mind it was a bit of a bloody hot day..
anyway, after waiting ten minutes.. car did start again, but you could here it miss firing in higher revs.. like, if i put foot down, it would misfire etc.. but.. if i graduly went up to those revs it wouldnt mind..
I got home, and my grandfather who is an ex mechanic, said it sounds like an over heatin problem with spark plugs or coil packs etc check your plugs.!!!
i know myn were platinum and were almost ready for a new set..
i hope this helps mate
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104382
Its me again,
I thought I would clarify what i mean by what happends when the car breaks down, the engine actually dies its not a matter of revs dropping , although being in the driving seat u see the revs lowering but if your engine is going to stop obviously your revs are going to drop.
I know its a electrical problem such as a sensor of some sort, is there any sort of check on sensors that I could do ?
what sensors could cause this.
ps monday datastream test hopefully will shed some light on the issue.
Keep you posted.
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104491
If you have a factory computer and a faulty sensor then you will most likely be able to get the fault code out of the computer, you can either do this your self or get a tuner to do it.
I think the codes are available somewhere in a thread on this forum, or you could go to Meggala's website as I'm sure it will be there.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104542
I'd imagine that suggests that it is not one of your sensors, therefore I think that coilpacks are the most likely culprit.
I don't know if anything will show up on the datastream test if the problem is intermitant, but good luck anyway.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-105055
Praise from the heavens above.
Finally, I took my car to Gavin Woods Auto Tech and the problem was that my car had to break down in order for him to work out the problem so i arrived at his workshop at about 10, I gave Gav my keys and he went for a spin I didnt ask him if it broke down on the drive but I doubt it did. Anyways he pulls into the workshop and the car is just idleing next minute its spluters then dies. I knew that this was gonna be it, probly the first time I wished for my car to break down and it did. He had the datastream computer hooked upto my car and he knew what it was straight away. The fuel pump is officially f***ed, Gav hooked up a fuel pressure gauge to my car and it was flowing about 30 on his gauge after he put his foot down it didnt really move and his eyes nearly popped out of his sockets. It is meant to be up around the 60 to 90 when hitting boost causeing my car to lean out dangerously and the computer says naaaaar stuff this and goes out for lunch.
I am now ordering a 500hp rating pump and on the way to havin a car which I can drive everywhere without being afraid of stoppin at light and or driving down the coast without being rear ended.
Thanks very much to everyone for your help especially GTS-t VSPEC,
take care guys.
:jump: :jump: :jump: :jump:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-105710
R324DRIFT,
Great to hear that your car is now fixed, and you were very lucky that it died in front of him, otherwise you would have had to wait until it had officially died before you realised.
I hope you have many km's of hassle free driving.
See'ya
:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-105845
