Personally for intank pumps I reckon you can't go past the jap bolt ins. ie. Nismo, Sard, Tomei etc. They actually do bolt straight in and are not too loud, plus they are reliable and have well documented flow ratings not some abitrary horsepower rating. only downside is they cost a lot more. probably best to get one from the usual on-line people like nengun or greenline.
Whats the best upgrade for a GTR fuel pump?
Where and how much?
Not a noisy 044...
Do the 044 upgrade PROPERLY and there isn't any noise.:rofl:
PS; do a search, this is one of THE most popular questions. This is a good thread to start off with, maybe you don't even NEED a pump upgrade.
http://www.skylinesaustralia.com/forums/sh...lts#post1281000
people who whinge about a nosiy 044 or 984, SHOULD BLOODY INSTALL THEM PROPERLY!!!!!!!
Used and installed about 10 044 and never had one thats been any nosier than stock!!!!
Wow, I am not the only one! I thought I must have been some sort of genius at quiet 044 installs. At least I know there is 2 of us.:rofl:
Where and how much?
Not a noisy 044...
you must be after big power yes? to need the upgrade , cos if you run decent size injectors and leave the pressure alone the std gtr pump will surport quiet a bit of rwhp (my std pump and filter 700cc injectors and Apexi fc 529.4rwhp 20psi) with no signs of it having a problem holding a very stable 11.9 to 12 a/f ratio
just from my experience
:) pete
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
