chirping 2nd in a s3 auto is a very common problem
especially when the auto is cold
sign of a worn box
and all the r31 diffs whine, and if it doesnt, it will soon enough
personally i wouldnt worry about the diff, just live with it.
gearbox should be fine, if it blows, they are worth nothing and u could find a 2nd hand one for like 100 bucks
we couldnt sell one from my friends car so we took it to the tip (and it was perfect)
umm yea sorry auto :D
what "slow r31" said: if you want it to last change the fluid every 4-6 months. if you look at the transmission fluid now is it very dark in colour almost black and grittie, if it is then i think its' to late to save or prolong its life.
Tell me if I'm wrong guys but does the R31 series use a Borg warner 78 diff ?
A friend of mine who's also a mechanic of many years once said that the late BW 78's were a bit soft in the ring / pinion gears . The fix is to source an early set from an old Cortina as the material spec was better . Not really sure of the facts .
Locally built R31's used the BW78 diff, as did VL's and VN's (and some Fords, I think).
With 200B's I think there was a Jap as well as the BW . Early Bluebirds got BW gearboxes and diffs but too many died and Jap stuff got the nod . There are some options for the local R31 followers . The 260 , 280 and I think 300C's used a H190 live rear end which would be probably wide enough for an R31 . They have 5 stud hubs and LSD is available though rare .
I'd say the best option is to fit the factory IRS which we did to a Bluebird or buy an import R31 that has it std . With local Bluebirds the mount locations are there but not the crush tubes and or studs . At least there's some chance of an LSD for an R200 and the ride / handling is so much better with the semi trailing arm IRS than the live axle .
Cheers A .
I had a SIII R31 until last year. It was a good car. They are known for diff whine, but that's not a huge problem. A rebuild and they are good for many more years. Or look through the wreckers for an LSD out of a silhouete.
the ride and handling were very good - mine was sensibly lowered. I ran as sweep vehicle for the Coastal Classic road rally a few years ago, which runs in conjunction with the QRC. And I got to run through the Hella Hillclimb stage (the only tarmac stage of the QRC) and get an official time. It would have put me in equal 4th out of the QRC cars on that stage, and one second behind Possum Bourne! lol! like I said it was a few years ago! but not bad for a dead standard auto RB30 on simex tyres and open diff! I did turn the air con off and shift it manually though! lol And the rally guys got to recce and pacenote the stage, although they had to run the forest tyres which would have slowed them down a bit. anyway, moral of the story is they can handle very well with the live axle for very little effort or money. that car had perfect brake balance too - just enough towards the rear so you could trail-brake into the turns nicely... front brakes faded a little too quickly with standard pads. They are a very underrated car I reckon.
hell yea they are underated
couple of my friends in the last six months have bought skyline wagons (sII and sIII)
and they trash there cars (one went through three cars in 6 months!), but these have stood up
to the challenge
they do all sorts of shit to them, one just today got a nice standstill going, without an LSD in the back, and with a car load of people
the r31's are rough, tough and take a LOT of shit
i had this done to my diff, using the cortina gears. it didnt whine initally, however it now does
thanks for all the info guys (relevant and non relevant)
i think if something goes wrong, i will know what to do
oh yea, how can u tell if the diff is an lsd
cause yesterday i trompt it at a u-turn, and i went back afterwards and both wheels had made marks (i think it was me anyway)
my friend did it at the same u turn a little while ago, and he doesnt have an lsd in his skyline and only the inside wheel spun
jack the rear end of the car up, so that both wheels are off the ground. handbrake off, and out of gear, make sure you have chocked the front wheels.
turn one wheel(either side, it doesn't matter which) if the other side turns the same direction, its lsd. if the other side turns the opposite direction, its an open wheeler
A few other fun ways.
Standstill - The ass end will start to go left or right
Romping - Flooring it in the wet the ass end will kich left,well mine does.
If it had a single shitter you will know coz it will always go straight unless you provoke it
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
