  • Replies 70
5th gear at 60, thats what, about 1000 rpm, thats pretty harsh on the box, on and off all the time, feel that clunky feeling in the stick, thats bad. 5th should really be used at over 80kmh. Plus u might need to put a bit of power down on the spot for an overtake or lane change and u cant do that at 1000rpm.
5th gear in a r32 with a r33 gearbox is roughly 2000 rpm.
This is with a rb30det as well......would that be too low to cruise at?
(the extra torque the motor has i can come out of a corner in 3rd doing roughly 1500 rpm and the rb20 turbo is already at full boost btw)
meh i change just after 60km, went it goes into 5th gear the revs are around 2000rpm, i cant see why it would damage/hurt gearbox if u shit below 2000rpm, if that is ture then pushing the car too 7100rpm and then shifting faster than average into another gear cant be good too :)
about 180km/h, 250m before turn 1 usually.
Yeah, 1000rpm is really too low, you shouldn't really be under about 1500, but you will hear easily if the engine is "labouring", its pretyt hard to pick pinging in a skyline tho
The guy I had driver training with once told me that between 2000-3000 rpm the car is "happy"
I re-evaluated that slightly when I got the r33.
normally I cruise round town (50-70kmh zones) in 4th, and only use 5th if I'm in a higher speed zone.
But I think the car could even handle cruising at 60 in 3rd really.
my daily driving shift points are 60kmh to 4th then about 90kmh to 5th... just the way i've always done it... that way i have some torque there if i should want to call on it :)
this is true, i hate it when im in 5th at like 2000rpm's and need to punch it to overtake or something
Yeh I'll shift_ *super lame Nissan bump right there, lol* into 5th at 80km... General 60km/h driving 4th... Sydney 60km/h driving 3rd... much more responsive for dodging the f#ct up traffic there. Constantly even shifting down to 2nd to quickly get past huge trucks about to squish up my car on outer lane. Dam I hate syd driving.
I don't bother doing the dogde left and right when city (sydney) driving.
It's more about knowing which lane to be in.
Anyway, i cruise along at 60-65 in 5th all the time.
4th when going up the little hills though and maybe an obvius overtake.
I love seeing other poeple jumpin left and right all over the place, punchung it off and on again.
Then i cruise along at about 40 and pass em just cause i know which lane will be better.
Hehe
i hate the feel of the car under-revin in 5th gear...like tryin to ride a mule up a hill. the only time i ever use 5th is 85-90 plus. id rather cruise in 4th gear at 3000rmp around 80km which is the max speed limits here anyways excluding hwy driving of course. you dont even stay at 80 for a prolong period of time before you hit traffic or lights. ill only whack it into 5th if the roads long enough or when traffic permits which is not very often. theres no way id cruise in 5th at 60 though, car drives like a dog and theres no power or response when a tricky situation arises.
Yeah im with everyone else, i switch to 5th at 80Km/h, 4th is at 60Km/h. But like going up a hill, i prefer to hit a lower gear becasue when u gun it in 5th, 1: it doesnt move, and 2: Boost goes on more...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
