  • Replies 70
  JeeTeeEss25Tee said:
I try not to shift gear at 3000 too often, any more is abit ouchie for the engine i think. Most of the time in good trafic condition I rev to 2500 then shift.
hehe, i think your missing all the fun, rb25 is quite capable of handling double theses revs happily :headspin: .
very rarely do i shift at anything less than 2.5k, unless in traffic.
does that make me a hoon?? :D
I use 3rd around town, only really get into fifth once I'm on a highway or something... I can't imagine using 5th in my car around town would be very punchy...
Um, I stay in 5th gear at any speed I want, even if its 50kph. It dosent take that much to keep your speed on the flats.
If I want more torque, I use the clutch and shift gears to whatever gear is appropriate (ie 4th or 3rd). When I'm done though it always goes back to 5th.
u guys are either petrol conservative or grannys in the making :P
You should never labor your car in high gear be that 2nd ,3rd th or 5th under 1500-2000rpm. I shift Up to 3000-3300rpm and change every gear unless my car is cold. Also 5th gear doesnt come into effect till im at LEAST 80KPH and drop bak to 4th till im at 60 KPH and into 3rd . :( call me a lead foot but thats just me
Some of you guys need to get some RB30ET torque up ya :(
When i'm in the mood I regularly just trundle around my suburb etc in 5th which is from around 50kmh.
I also quite regularly skip gears ie Only use 1st 2nd 4th.
Hope soon to come RB26DETT has some useableable down low torque, as I'm becoming quite fond of it :P
Granny Driving...
revs stay at 2000rpm when cruising, drop down when below and shift up at 3000
3rd - 40kph - 60kph
4th - 60kph - 80kph
5th - 80kph or greater
Normal driving...
a tad different.... the 2000 rpm cruise rule is kept, but gears become...
3rd - 40:D
One thing to remember is that you want yr rpm to be such that if you change down you end up in the meaty rev range, this means that dropping a gear and hammering is always an option and you'll avoid bogging the turbo down.
