I love seeing other poeple jumpin left and right all over the place, punchung it off and on again.
Then i cruise along at about 40 and pass em just cause i know which lane will be better.
Hehe
:rofl: Our family car used to be a 47kW auto corolla. Lane choice was all i had... but as you said, it works!
Mark
  • Replies 70
I too cruise around at 50km/h in 5th. Put the foot down a little boost comes up quick and accelerates away easily.
Since the new motor I also find my self pulling out of corners/round abouts in third and fourth from as low as 1000rpm.
I've always dropped it in fifth when cruising at a steady speed.
If I need to accelerate, drop it back a cog.
Maybe this is why I used to get 470km's to a tank of juice (50l) with the rb30det and recently managed 520km's from the rb30det? :rofl:
Maybe this is why I used to get 470km's to a tank of juice (50l) with the rb30det and recently managed 520km's from the rb30det? :P
lucky you i get about 200ks to 50l
170km/hr or so when you run out of 4th :rofl:
in the old r33 manual i don't think i ever really used it too much, except when on the freeways at 100km/hr (even then thats the top of 3rd if you are really hammering it).. but that was melbourne/crapville. I used to see 5th as the "sleep gear" - leave it and you tended to nod off .. :headspin:
i can't believe so many of you drive in 5th at only 50 or 60kmh!! It just feels wrong!
i usually change at about 3000rpm and only use 5th when I get to 90-100kmh!
if i had to sit in an 80 zone for a while i'd probably whack it in 5th, but if that dropped to a 70 zone I'd have it back in 4th...
Have a look at dyno read outs it shows the torque curve starting about 2200 on mine anything below that is hurting you motor. Read execive wear as oil is not up to it and if you listen you'll hear your motor groaning and its saying put me lower gear please.
If you are cruising you have very very minimal load on the motor.
With minimal load it doesn't hurt the motor to cruise around at low rev's.
My peak torque is at 2000rpm. 100rwkw which is around 150kw at the flywheel, using the formula Power = Torque x RPM / 5252 that would equate to some where around 740nM of torque. :rofl:
Sounds almost unrealistic.
I don't get it, I always cruise around in 5th so long as the car feels like it has enough "go".. ie down hills or higher speeds.
Why is it bad under 1000rpm?
are you serious? under 1000rpm the engine is either about to stall or blow, putting that sort of strain on the engine is just lazy - change up a gear.
Its actually something you can pick by ear. if the car is loading up it vibrates and sounds like shit bascailly. I found my rb20 if ther are no hills, and im not going to accelerate at all 70km/h was ok, but realistically 80km/h without putting excess load on the car
Ok after reading a lot of posts of why driving at lower revs in x gear is bad... anybody want to mechanically explain why its bad. It's all good to say something but without anything to back it up it means sh#t to me. I can see this thread as the type of thread which attracts lots of comments from kids who don鈥檛 really know what they鈥檙e talking about so that鈥檚 why I ask somebody to mechanically explain it so I can take the explanation literally & put those actions into place if I feel I need to.
Cheers,
Cheers,
Have u even ridden a mountain/racer bike up a hill very slowly in the highest gear or gone from stationary in the highest gear??? If you have u will know it takes alot more effort/force/energy to do so than if u had it in a lower gear.
Same goes for an engine being loaded at a slow revolution in 5th gear where it is getting an unnecessary load applied to it
Ok so how is this 'load' physically hurting the engine... name parts exactly...
Trying to ride a mountain bike up a hill in a higher gear doesn鈥檛 actually physically damage me, I'm simply not able to do the same thing 'pedal legs' as fast as if in a lower gear, no damage, just reduced speed / power / torque.
So now we come back to an engine, how is an engine different at lower speed as it is at higher RPMs. *pistons, crankshaft, cams, all move the same still, just different speed depending on RPMs*. Each piston ignites creating x amount of torque at the given RPM. Now once the RPM is low enough & cannot create enough torque to move the car in the higher gear how is this actually damaging the engine. Isn鈥檛 the engine really just doing the same thing as it is at idle RPM, the internals are still all moving the same BUT the only difference at that same low RPM a lot more Air & Fuel is being injected to try & get the car to accelerate at that low RPM.
This is my understanding of an engine & trying to get some explanation why low RPM in high gear is actually physically damaging / harmful to your engine, I heard someone say something about Oil before? Is oil the final factor? But at the moment with my limited understanding of engines I cannot see why an open full throttle at low RPMs is bad. Please correct / enlighten me.
dude why the hell would u even change at 2500 rpm's thats just silly
skylines can handel 5000 or 5500 quite ok
are yous all stingy with your petrol or did your pops teach yous all to drive
:D
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
    • Final thought for now. Obviously the reason I was in there was to check everything is OK cooling wise, pull out the radiator to flush it etc, but I have to say the factory has done a hell of a lot of thinking about air management in a way they never did back in the R chassis days. The Redsport/400rs have (from engine forward) 2 large shrouded fans - radiator (incl AT cooler) - AC condenser - Intercooler Heat Exchanger and Oil cooler. There are shrouds and foam around everything to keep it pretty well sealed, which is good in that they have it sorted from factory, and bad in that I can't make any meaningful improvements there. The second red sport pump water pump is mounted in front of the rad in the airflow, so I will see if there is somewhere else I can stash that (unlikely, it is tight in there). The horns which are also in the rad airflow will be moved somewhere else, and hey who needs 2 when 1 would work For track days, I can also remove the lights which would block some airflow. Factory has already taken the smart option of ducting all air that went through the oil cooler down and out of the engine bay. This pic is taken from below looking up, so air comes through the cooler at the top of the pic then hits the shroud and is directed down and out of the engine bay through the engine bay lower cover Which of course is good for oil temps, but doesn't help the rad as it diverts 10-20% of airflow away So, no big improvements to be made here, I'll flush the rad out and put it all back together.....
    • It looks so incredibly busy in there! 馃槷
    • Next..... That escalated quicker than an Elon and Donald break up! I'll post up a specific DIY for radiator removal on these, but all I'm saying is that if you get a workshop to change your radiator for any reason and they give you a $1000 bill for it, go and hug them and thank them for not charging all the hours it took.....what a bastard of a job. I'll make some adjustments as I put it all back for faster access in the future, but it was a nightmare.
