Hey Prank,
The timezones are a bit screwed up. It looks like it's 9 hours back. I don't know if this is a stuff up on my end but in my profile the timezone is set to the Sydney one so you might want to check this out.
Also, can you explain to me step by step how to upload my avatar. I'm having a bit of a problem getting that done. It's on my local drive.
Cheers.
https://www.sau.com.au/forums/topic/7-timezones/
Hey Man,
I am trying to work out whats wth both of these. In admin, I have the timezones set to +10 for sydney, but its wrong ?!?
Also, I am trying to work out how to have avatars uploadable.
Sorry guys, will get to this ASAP.
https://www.sau.com.au/forums/topic/7-timezones/#findComment-104
Ok, there seems to be an issue with the timezones, if you set your profile timezone to 15hrs behind your actual timezone, it will work. ie, my timezone is +10 for sydney and I just set it to -5 and all the times are now correct.
As for the avatar uploading, I am still working on that.
Christian
https://www.sau.com.au/forums/topic/7-timezones/#findComment-107
yeah when i change my settings in profiles it changes the time of posts.. however in the config area in the admin section it doesnt affect it at all..?? hmm i wonder if u have to close the forums for a while to change the date there.. or maybe even the date of where the board is held affects it.. but i doubt that :P.. arghh this is bugging me
https://www.sau.com.au/forums/topic/7-timezones/#findComment-118
