  • Replies 54
hey ben
i got the pieces in the mail today
will install it either later tonight or 2morrow and post up the results
cheers
Eric
p.s great seller to buy off, quick replies and even quicker delivery =)
REVIEW
Hi, i promised ben i would write a review/feedback after i installed it so here goes.
I paid my money and got the boost piece in the mail about a day later (props to a great seller)
It was extremely easy to install. If I could do it in less than 5 minutes, anyone can
Stock boost on the r34 is around 5 psi low/ 7psi high (correct me if im wrong). As the boost piece replaces the solenoid, it becomes a constant high of around 10 psi (give or take 0.5 psi). This is better than the constant ground to the solenoid as it prevents the risk of damaging it. Full boost of around 10psi comes on under 3000 rpm (probably a bit less but i'm not very good at looking at the road, speedo and boost gauge at the same time). This then drops down by about 0.5 psi to around 9.5 psi or so.
Overall, its a great purchase for those that only want a little bit of boost increase. In my opinion, its only $20 or so and definately worth it for the gain.
Cheers
Eric
I got one of these delivered last week with a similar experience to ecl only on an R33 GTST sedan. 5 mins to install, great very clear instructions and the promised result of 10psi.
And for an added bonus I went to a dyno day today and with only a catback 3" exhaust, R34 stock intercooler and the magic 10psi and I recorded 176rwkw. I am very suprised at the result as there were a couple of stock 33s there that recorded the expected mid 140rwkw for comparison. Big thumbs up. Also there was no detonation but the car was quite rich :D . Big thanks!
I have sold about 14 of these and I have had feedback from about 10 people so far. All except 2 have held 9-10psi as they requested, however 2 people that have had automatics have been seeing around 13-14psi!! I am in the process of sending them more conservative ones.
I find this strange but if I find this to be consistent trend then I will have to have a manual one and another for automatics...
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
