If you want the full list use the Dotars site
http://raws.dotars.gov.au/rawswebpublic/RA...AWPubSearch.asp
I used Carmen Import Centre for my R33 under the old scheme
I could not recommend a better bunch of guys to deal with
Talk to Craig Walker on 07 3881 1800 their at Brendale
They have R33 under Raws and soon R34
Normal prices are $4500 plus GST plus tyres
Andrew has offered it to me any anyone I know and send his way for trade price of $3500 plus GST plus tyres
Give him a call, he is very happy to chat and help out.
Just mention you know me thru SAU and the price I quoted.
What are you wanting to comply? My uncle complies R32 GT-Rs and GTSts. I'm sure he would charge a very competitive rate as he's just trying to get his own business off the ground. Can also take care of any maintenance.
He's very good also as he's got 30 years experience as a mechanic and built his own 11sec car from the ground up.
I just got him to change the timing belt, brakes and do a general service on my skyline.
His name is Neil, you can call him on 3848 7788 or 0432 358 208 if you're interested.
There is another one called Tuff Toys near the gateway bridge...I got new EVO6 and Twin Turbo Supar comp there...but I saw them doing 33,34,GTIR,FTO as well...I dun have their number on me....but juts call the number 1223 and ask for Tuff Toys in Brisbane....
Good Luck mate
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
