I have recently decided to get my car tuned and was just wanted to get some feedback off you guys in regards to how much boost you run. (preffibly from those guys running similar mods to my own).
Its an r33 gts-t, stock turbo, fmic, eboost cont, hks air filter (with cold air intake), SAFC2, 3' exhaust all the way.
Car is about to reach 100,000km.
I've told the tuner id like the turbo to last for quite abit longer, so hes suggested to tune it at 12psi. Personally ive never boosted the car more than 10psi, but he has assured me 12 to be safe in most cases.
Just wondering how many of you run this on a daily basis, and if you've had any problems?
https://www.sau.com.au/forums/topic/70117-r33-boost-levels/
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
