Okay guys after reading the spotted thread and finding no one had started a thread for the sydney cruise im doin it!
Lets go some suggestions
Time
Place
to BBQ or not to BBQ?
My car now works perfectly and I'd like to see some of you again and meet some more of us "rare breed" ceffy drivers
  • Replies 124
love to drive to byron ....except for all the friggin speed cameras and if itravelling that far i would rather stay the week etc....
but yea im up for a drive ....
hunter valley?.....
wollombi road is an excellent road for driving on....
...well it depends if its one day .....port is probably a little far ......i think ...take 3.5 ours to get there ....3.5 on the way home theres 7 hours already gone.....maybe a weekend for that .........
u dont want to sit in the car the whole day ......
but if everyone else wants to do that ...i will come too ! hehe
Go to the Vineyards and go wine tasting. If your concerned about possible RBT's, You can be good and spit, or you can be bad and swallow :P
Plus the Newcastle mob might join up with us.
HECKTIC4DOOR I like the bathurst Idea, although the track is more jailbait than 15 yr old girls. Bells line of road is a great drive, the second day I got my car working I went up to bell for a swim.
I'd also be up for the gong too, some great driving around there but I don't know the area, im easily pleased and will drive anywhere -short of byron although I do love byron but I need a week of work for that ;)
Northern beaches? - coz im aware a fair few of you guys are northershorites
I wouldn't be too keen on going much further than 2 hours or so from the city. that'd be my limit
ill be in for whatever presuming i have no work on,
my suggestion is the gong, about an hour from sydney, maybe head there or back through the national park(but some parts of the road are a bit rough),
north shore sounds good too seen there seems to be a few people from that area
im happy to go wherever though, id say about 2 hours would be my limit too..
and bbq sounds good
If this BIG cruise can hold off for a month or so i will on like donkey kong. The Ceffie is still not on the boat so could be a bit over a month!
I am also Northside so if the cruise goes ahead it's here, i may be a passanger sl*t, if anyone is willing!
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
