YES DELAY CRUISE!!!!! Just got confirmation da Ceffy is on the water and should landed here in about 2 weeks.......so w/end 28-29th of May or maybe beginning of June.... is good for me and i will be out and about in my purple people eater :cheers:
Ando
  • Replies 124
I don't care where we go!! I will just be happy to behind the wheel of my Cefiro finally! Should be great so have a large turnout of Ceffies!!! Maybe we could head up to wisemen's ferry way??? Maybe south to towards the Gong.......not too keen thou for a large drive. Oh maybe head up the mountains to Leura or something....hhmm nice cold turbo induction air goodness :cheers: Really not fussed! Maybe we can organise a meeting point @ Homebush Carpark P6 and even the Cefiros from 'Northside' (think theres about 4 or so) can meet at say Chatswood or somewhere local and head to homebush together???!!!!!
MY 2 CENTS
Ando
Where is the cruise?
Undecided but i am keen on the idea of heading to mountains...IE lithgow....Leura etc...just my thought. Meet at Homebush P6 in morning
when are we going on the cruise?
Weekend of the 4-5 June....Think we should lock in the Sat 4th as some are busy on the Sunday
why aren't we going on the cruise now?
Because a couple of people have pleaded to hold off (like me oopps) for various reason...commitments, car mods, etc
and so on and so forth....
Sorry to anyone who was waiting for me to make a decision (your all very capable though :wassup: ) between a buisy work schedule and a crippling GT4 addiction I haven't been on the forums of late.
Now I have an F1 car on gt4 and im in a comfort zone I can put the controller down...
Who wants to go on the 4th June? Say meet at Penrith Panthers car park, then we can go pretty much anywhere we like from there, West out bells line of road to lithgow and back or south to the gong is a very easy straight forward drive...
im open to suggestions!
So whos up?
Due to a buisy work schedule and a horribly crippling GT4 addiction (at least I have an f1 car now) I ahve finally got back on to the forums...
Hey I like the idea of the 4th how about we meet at penrith or somthing like panthers carpark then we can go pretty much anywhere from there.
Up bells line of road to lithgow and back down?
South to the gong thats a straight forward easy from penrith?
Im with deviat so who else is up for the 4th???
Alright well it seems that the 4th is a goer! Sorry to hijack the organising but i am keen as mustard to take my new baby out for a cruz with other cefiros! She is on the docks and should be picked up next week sometime!!! WOOT!
Okay the PLAN
4th June 2005
Meet @ 10am at Penrith Panthers
Depart 10:30am SHARP!!
Head up Bells Line road to Lithgow
Lunch up there 'somewhere'.........
Head back say around 2-3pm, should get us back in Syd about 5-6ish!?!?!?!?!
Sounds like a plan???? I am open to other destination suggestions but a drive up the mountains sounds good to me!
For the boyz living around the north side we can say meet @ 9am somewhere local......dunno maybe Chatty area...not sure!
MY 2 c
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
