Thats it im taking Initiative- Sydney Cruise Time!
Okay well i think the date and destination seems to locked in.
4th June,
Drive to Lithgow, via Bell Line Rd, lunch, hang around & head back.
As for meeting points i think that Penrith Panthers sounds like a good idea for our main point of meetup. :) What i was thinking was maybe have a second meeting point for the Cefiro's from around the Northside area to meet @ the Shell Petrol station on Epping Road, Lane Cove. Commonly refer'd to as 'The Space Station'. I think most people who live around that area know the one i am talking about. So all that want to meet there, rendevous for approx 9am, then head out to Penrith for a 10am meetup with everyone else. Sound good?
Check the pics below for map locations for those not so sure. If there any objections to any of this, please jump in as i am just simply making suggestions!!!
P.S. Nytrda, depending on where u are coming from, either place is pretty easy to find....just bring a street directory for Syd lol :)
If you have any trouble ill PM you my mobile # closer to the date.
Cheers,
ANDO
  • Replies 124
4th of june sounds good to me, ill be there if it all goes ahead. :rofl:
R33Deviat, are you sure you'll have your car rego'd and drivable within just 2 weeks? that can take a while sometimes.. (not that im saying you wont be able to, the sooner the better)
matt25 - Mate it should be all good. *fingers crossed* If it turns out that it aint gonna be ready in time well....nah not even gonna think that, i will be behind the wheel next w/end....lol *wishful thinking*!!! Who knows!!
Woooo! All Sounds good to me! I'll be there at 10:30.
Just to narrow the area down a little, panthers carpark is absolutly Massive so we'll meet between Krispy Kremes and maccas - that sounds vague, but when your going down the main driveway you'll see where I mean.
CC - I live (unfortunatly) close to penrith I drive my ceffy through there every day to work and yes on a thursday or a saturday night Maccanats @ panthers is rediculous with the amount of wankers in modified cars (mostly civics with sports zorsts and BIG TACHOS! bro.) but the cops aren't a problem, especially on a sat morning.
Especially considering all the ****suckers that pull smoke shows there on thursdays and saturdays, somehow they get away with it... so i think a bunch of us waiting to meet up there won't be a problem
I have never been pulled over in penrith in the cef. Been pulled up in the mountains a few times though... Lousy mountains...
Hey dudes, if there is a another alternative to meetup and destination to drive to, i am sweet with that. I just simply came up with a few suggestions. Its still a good week and a bit away so still plent of time to reorganise something. Just think may wanna stick with the 4th June as the date
Since it's up to a week away we should get confirmations/numbers.
R33Deviat noone has seemed to say anything wrong with the location so I'm sweet with it if everyone else is.. i just hope my car makes it there.
Can we get a show of hands please people?
I'll start - I'm there!
myself and sky80y will come to shell on epping road (not 100% sure about the cruise, sky80y's got work at 12 and i would've finished my 9hrs shift from the night before finishing at 8am on saturday) :spew:
I might come to the meet up at penrith for a bit, but i don't like the idea of putting along bells line with all the saturday drivers and camrys and trcuks and stuff doing 40kmh, so i'll go home when you guys head off. You should hang around the Penrith meet for an hour or so
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
