in my r33 gtr centre console just behind the gear stick there are 2slots for switches. the one on the left activates the park lights which either press forward (numbered I) or backwards (numbered II). i cant figure out the purpose of this switch cause u can do the same thing on the indicator lever...????
The other slot next to parker switch has been removed and i was wondering
wat used to be there???
does anybody know?
https://www.sau.com.au/forums/topic/70178-r33-gtr-question/
I don't even have any switches there, just 2 coin holder type things and a GTR emblem...
are you sure its factory on your car?
im not sure its factory, i have a coin holder on the left slot, the middle is the parker. and the right had a switch of sum sort which is now missing.
where is ur GTR badge? i dont have one.
https://www.sau.com.au/forums/topic/70178-r33-gtr-question/#findComment-1298247
my model number is ggjprwfr33zdagj if that is any help..?
im not sure if its the original console but i'll post a pic this weekend for u guys.
can u post a pic of urs?
the coin holder is molded in so it doesnt look like u can pop it out for extra switches unlike the other two.
https://www.sau.com.au/forums/topic/70178-r33-gtr-question/#findComment-1300144
Some 33 GTRs were fitted with factory fog lights, a friend of mine had them on his 33 before he removed them. The switch for them was located there, mine sounds the same as ferni's and Tommyk's though, just 2 coin holders and the GTR badge.
https://www.sau.com.au/forums/topic/70178-r33-gtr-question/#findComment-1301385
i dont understand the reasoning behind the use of that parker switch because u can do the
same thing on the indicator stick. its also a 3way switch, forward (numbered I) middle (off) or backwards (numbered II)???
this is wat mine looks like
https://www.sau.com.au/forums/topic/70178-r33-gtr-question/#findComment-1302686
  • 2 months later...
hey guys, i have a 33 gtst and i have the same sorta switch but its mounted up on the slot to the left of my stearing column... but i do have the little gtr emblem which is kewl, but im just wondering what you need for the fog lights, you flick the switch up I, down II and the parkers come on, but i need some globes/cradles for the fog lights.. the wiring looms all there i just need something to go in it, does anyone know what globes you need?
https://www.sau.com.au/forums/topic/70178-r33-gtr-question/#findComment-1444533
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
