Hey guys
I have decided to change this group buy into a 400R front bar group buy. I have just found out the order cannot be placed for 2-3 months as they are Very busy completeing a large order at the moment.
Pricing is now below
1-4 - $415 Each
5-10 - $395 Each
Payment - A 50% deposit will be required when the order is placed as to cover the costs to me and my supplier.
Shipping will be around $30 at you door but i can confirm the price when i know the weight of my 400R front bar.
[1] -
[2] -
[3] -
[4] -
[5] -
[6] -
[7] -
[8] -
[9] -
[10] -
Please note the bar below isnt finished but i will post updated pics when i recieve it.
As far as other gear goes i will display that info in time. They are currently working on a kit for R32 GTST 4 Door.
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/
This doesnt sound like a group buy ibfalcon.
If you can supply certain parts at good prices thats fantastic, but you will need to become a trader if you wish to sell these parts here.
Please pm me for more info
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1296811
Hey guys
I just want to see if there was any interest in getting skyline bodykits. Eg i can get a 400r front bar for a r33 gtst for 410+ shippping. I am also able to supply indicators.
There are other kits available too at good prices.
Lee
Im interested in buying a body kit how much are they and what kind are they?
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1299009
Hey guys i have just applied to become a trader. I will post details after my application is processed i dont want to get on the mods bad side.
Can you get these:
Side Skirts
400R Front Bar and skirts
What im after (depending on price) is either the white front bar with the white side skirts or the Black 400r front bar and black side skirts. So if you could get two prices on the two kits it would be much appriciated.
Cheers,
Mitch
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1309812
it aint a 400r front bar www.nismo.com.au have a look at their version of the 400r front bar its fairly decent compared to the REAL thing
I like it better than the 400r front bar, its more unique not many ppl have them were as everyone has a 400r front bar...
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1314869
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
