Time has come to sell and move on, have had my fun and want to pass it onto someone who will appreciate it. Details below
1996 Series 2 Nissan Skyline GTS-T
Jet Black
Motor
Fully Rebuilt and Balanced
Wiesco Forgies with Gapless Rings
PAR Steel Forged Con-rods with ARP bolts
Polished and Strengthened crank
Head has been race ported and polished steel values and springs , Tomei Cams, receiver groved for O ring
Induction
Turbonetics 76mm turbo (1000hp)
Tial 38mm Wastegate
Custom intercooler
Custom Plenum
3 inch exhaust
Management and Fuel System
Microtech LTX12 with latest upgrade and 3 bar map sensor
O44 Bosch fuel pump, 1 Litre Surge Tank
SARD Injectors (850cc)
Trans and Diff/ Suspension
Ford C4 fully built by Als Race Glide
3500 rpm stall
Huge Trans cooler
R33 Nismo Diff
Pedders SportsRyder Springs
Rims
Kaotick 20” x 10.5
Top the range Falken Rubber 20/35/275s
Interior
Custom Leather interior Champiage Colour
Recaro Bucket seats
EBoost guage
Pioneer touch screen DVD player
12” pioneer Sub
2way front Splits Bullet
3way Rear Splits
Lot of people will know this car, there is lot of other bits pieces I haven’t mentioned, will get pics up soon.
Built and serviced by Pro Form Engine Services
Car has gone 10.6@134mph previously manual gearbox , should easy go low 10’s high 9’s now, car is big $$$ spent on all good parts.
Price is $40,000 or Swap for Late model R33 GTR
https://www.sau.com.au/forums/topic/70221-for-sale-500kw-10sec-r33-gtst/
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
