  • Replies 136
Guest Emperor
Hi guys,
Just wanted to get some eoi of what carbon fibre parts ppl would be interested in.
I and a couple of friends are able to fabricate parts out of carbon fibre would like to find out what kind of parts everyone would need. We're thinking of smaller sized parts not the obvious Bonnets and that, which we can do as well.
Just a note: my friend (the main fabricator) has a lot of experience with carbon fibre, including helping build the UWA motorsport car (carbon fibre monocoque chassis - yes same as F1) so they will be of proffessional quality.
Some possible ideas.. carbon fibre surrounds for rear lights, mudflap surrounds, front light surrounds, eyelids, etc..
hey Quink,
I would be interested in the following parts for an R33 S1
-Air-Box
-Eye Lids
-Headlight (the ones which u remove ur headlight and it is just like an air-duct to filter, if photos needed will post)
-Flat Boot (very very interested in this)
-Mudflaps would also be cool
-read lights surronds and front lights too
-Engine Cover RB25det
-GTR style grill to suit gts-t
Hey guys, thanks for the replies and keep them coming..
Well i'm meeting up with my friend today with these suggestions and get a rough (note very rough) cost vs construction method write up for you guys and whether u'd still be interested.
It seems the most popular suggestion is the R33 Flat boot lid, with 5-6 ppl already very interested.
Just a couple of points to remember is if u just want a skin on top of fibreglass etc.. its gonna be a hella lot cheaper than a fully carbon one.. as well as building a fully functional carbon fibre door instead of just a eyelid... Price vs Weight vs Complexity.. will be the key issue here..
Well i would like R32 GTR style bonnet, carbon skin just fine......hell im looking to buy just a plain fibreglas one with some choice drift style vents etc.....then just spray entire car....basicly....cheap is GOOD :P
I'm down for a flat boot, dont care if its fibreglass or carbon fibre
Hi I am interested in an R32GTR airbox to suit Apexi pods. preferably carbon fibre side(s) and perspex top (so the filters can still be seen/inspected).
there are a few designs around and I could send you a link if you want to have a look.
I'm sure there is plenty of R32GTR owners with Apexi pods who would buy one.
I would be happy with a Flat boot with cf layer, or just full cf :D
understand what you are saying quink :P i'd go either a fibreglass flat boot with a cf layer or full carbon but would prefer full carbon and be prepared to pay for the time and effort if the quality was good, which from the sound of it, it would be.
:D
I'd be up for a skin bonnet and r32 GTR grill for sure. (cheap is good, but I'd like a full carbon price....)
Also some gauge holders would be heaps useful.
Pod box :)
Eyelids would also be awesome. Cheers champ!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
