  • Replies 136
  • 3 weeks later...
Nope, still going ahead, sorry for the lack of update, but we're currently making bike parts. We have also bought an R33 rear boot lid, and will start building that up soon, make a mould and make sure things work, and other things like finalising brand name and logo's and that.
Other than that people have been busy with their day jobs/ exams.. but dont worry we're still going ahead :D
R33 Bootlid? YES PLEASE :lock:
I would be interested in a flat drag type boot spoiler, also not sure if anyone else would be interested in, is a 1 piece c/f door trim, I would paid $1500 for each door trim.
to suit R33 series 1 gts-t
bootlid
stealth/drift style wing
front eye lids
front GTR style bonnet lip (air splitter)
Rear tail light surrounds
Cold air partion to suit POD filter
radiator air guide ( bit that sits ontop of grill)
Dash kit, cluster surround, gearstick surround, centre console, glove box even...?
all depending on cost....but the more i can convert to carbon....the better :) I love the stuff
:D
would vented vf bonnets be a hard/expensive job? im very interested in one 4 an r32 gtst but in the gtr style! and my friend would also like 1 for his S2 r33... i think they would be as popular as the bootlid
Interested in a vented R32 Gtr bonnet or Gnarly vents to put in .
centre consoll and vent gauge mount 52 mm ID
id be interested in a c/f dash or the bit in an r33 that surrounds the steering wheel and cd player. and even the part the goes arround the gear stick around the leather boot. these i think would sell good too as heaps of guys are trying to paint there interiors, but a c/f look would be great i think.
  • 3 weeks later...
  • 3 weeks later...
Guest
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
