Whilst my car was on the hoist the other day I had a good look underneath & discovered it was fitted with adjustable castor rods. ;)
My front tyres a looking a little sad after a day at Wanneroo, however I only have maxed out stock front camber & castor, ie approx 1 & 3 degrees respectively. Without making it too track biased I would like to use more castor at the front.
The question is two fold:
What other bushes etc do I need to take maximum advantage of the rods?
How many degrees castor is recommended for an R 32 GT-R?
https://www.sau.com.au/forums/topic/70230-r32-gt-r-castor-rods/
As much caster as you can wind on without wearing out the plastic inner guards.
Camber is non adjustable unless you have some bushes but if so, approx 1.5deg neg will give a good compromise between tyre wear/handling.
For track work with comp style tyres I run 2.5deg and for wanners 3deg neg.
Cheers
Ken
Cheers
Ken
Thanks Ken, are you able to quote a typical figure?
Also do I need any other bushes to adjust the castor further (as opposed to camber)?
No, you have rose jointed caster arms so there is no provision for extra adjustment bushes.
Typical figure on a good one is around 5 ish deg neg. Have seen up to 7 but that was with low profile tyres and special caster rods that extra thread machined in.
The more caster( within reason ) , the more the steering wheel will come back to self centre quickly and the *nervousness* that sometimes occurs on patchy roads is diminished.
Setting up a GTR for track is tricky and there are lots of variables involved including ride height, toe settings, spring rates, sway bar settings, tyre pressures etc but camber and caster are 2 of the more important angles needed for a well handling, quick to turn in and balance GTR.
Word for the wise is not to go too big on wheel size/wheel offset as the GTR's don't like having the big offsets that put wheels against the outer lip of the guards. They will tramline and steering wheel pull something terrible on rough bitumen or on wet and puddle filled roads.
Cheers
Ken
I have always wondered why the adjustable rods have no form of bushings on them, like the stock items... Will this cause any damage to where they bolt in? they just kind of look like they are sitting "loose" in that space there.
Which is better, having adjustable bushes with offset adjustment to alter camber or the separate adjustable arms (like the above photos) ? There is about a $150 price difference..
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
