Hey Guys,
Im interested in getting an electronic boost controller
I went into AutoBarn and seen a brand called Gizmo
They were selling them for around $480.
Any know if their any good or crap.
Any suggestions on which electronic boost controller is recommended.
Nothing over $600.
Cheers ;)
https://www.sau.com.au/forums/topic/70249-electronic-boost-controller/
']you can get a Apexi AVCR, for brand new for $600,
Hey, well the greddy profec spec b ii does the same job
Apexi may have more features but i dont care for features
As long as its reliable and does the same job im happy,
I got a quote around $400 for the greddy boost controller
What do u think.?
What do u think.?
apexi one is good but, it isnt good unless setup right. I have heard only hood things about the profec ebc, i own a profec A and it works wonderful, i belived spec b, is daul sol and is very good
What do u think.?
If you just want someting cheap and reliable why not go for a BLEED VALVE
almost guaranteed never to break down...works without eletricity too :)
bleed valve is not exactly relibable. a cheap ebc will serve its purpose and be accurate. i got a 2nd hks evc for $250 and it works awesome, i had a problem with it last week but it was just loose wiring. does awesome boost control
for something that needs to be reliable in it's performance such as a boost controller, i think you're best to go for a well known unit.
the jaycar boost control is fine if you have the time and knowhow to set it up, but if you're like me and just want something that you can get fitted and basically have no worries with go for AVCR or SBC idIII.
both can be found for around 570-630 new.
get the profec , or you can get a blitz ssbc for about 400 also .
i got a second hand old blitz ssbc off the forums , here . it didnt work . luckily the guy gave me back most of my money , got a 2nd one of the same type and replaced the faulty control unit . so it cost about 200$ all up and ive got some spares just incase .
I generally email the instructions and pics to ppl, as I can't get the pic's up here (too large). Any ideas?
For anyone else interested, here are the photo's/instructions DAN00H was talking about.
Pics to be read in conjunction with word doc
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
