Hey guys,
One of the wires going into coil pack number 1 has come out of the plug, effectively giving me 5 cylinders :D
how the hell do i get the yellow bit of the plug out so i can rewire it into it?
or where do i get a new plug/harness?
And i seem to have blown my exhaust manifold gasket ;)
I know beau had this problem, whats it cost to get done, and whats the gasket price itself?
ive had a great few days :P
cheers ;)
i thought i had a receipt around here but i've misplaced it for now.
Inlet and exh manifold gasket will set you back $185 together. That price was from Metro Nissan @ Windsor.
I would assume the exh gasket to be more expensive.
u can crimp some spade connectors onto the wiring and connect them up that way.
my rb25 seems to have that arrangement for one of the coils.. if u like i can take photos.
nissan apparently has plugs though..
Yeh i was thinking that, but ide rather do it properly
is there anyway of pulling the plugs apart to reuse them?
even if i buy new ones i dont know how to get them open to solder/crimp the wires in etc
guess ill check the plug properly and see if there is a code on it somewhere
cheers for the replies,
i just swapped a mates coil pack harness to use for a few days :)
i tried to reuse the plug but it was fairly brittle/coroded and ended up cracking to pieces pretty much, so off to nissan to see if i can get new plugs, that or i call zoom/alljap and see what a 2nd hand harness is worth
whered you get that from?
im hoping a new coil pack harness from nissan isnt heartattack priced :Oops:
oh yeh, the leak turned out to just be the gasket from dump pipe to frontpipe, was leaking pretty bad, blew a whole section of gasket out, hence the noise was pretty loud.
is a hell of alot easier and cheaper to fix than the manifold gasket! :)
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
