Hey guys,
One of the wires going into coil pack number 1 has come out of the plug, effectively giving me 5 cylinders :D
how the hell do i get the yellow bit of the plug out so i can rewire it into it?
or where do i get a new plug/harness?
And i seem to have blown my exhaust manifold gasket ;)
I know beau had this problem, whats it cost to get done, and whats the gasket price itself?
ive had a great few days :P
cheers ;)
i thought i had a receipt around here but i've misplaced it for now.
Inlet and exh manifold gasket will set you back $185 together. That price was from Metro Nissan @ Windsor.
I would assume the exh gasket to be more expensive.
u can crimp some spade connectors onto the wiring and connect them up that way.
my rb25 seems to have that arrangement for one of the coils.. if u like i can take photos.
nissan apparently has plugs though..
Yeh i was thinking that, but ide rather do it properly
is there anyway of pulling the plugs apart to reuse them?
even if i buy new ones i dont know how to get them open to solder/crimp the wires in etc
guess ill check the plug properly and see if there is a code on it somewhere
cheers for the replies,
i just swapped a mates coil pack harness to use for a few days :)
i tried to reuse the plug but it was fairly brittle/coroded and ended up cracking to pieces pretty much, so off to nissan to see if i can get new plugs, that or i call zoom/alljap and see what a 2nd hand harness is worth
whered you get that from?
im hoping a new coil pack harness from nissan isnt heartattack priced :Oops:
oh yeh, the leak turned out to just be the gasket from dump pipe to frontpipe, was leaking pretty bad, blew a whole section of gasket out, hence the noise was pretty loud.
is a hell of alot easier and cheaper to fix than the manifold gasket! :)
