I have been looking at alot of information relating to cars power output. Now most people say well on the dyno it did 200hp but on this dyno it did 300hp so therefore it must have 300hp, but as we all know differnt dyno's read differently and other factors come into play.
So how would you measure your cars power accurately, i have read allot about MPH at the track as in general around 120mph mark will put you in at around the 400hp mark. once again lighter cars will have less power but still do around that MPH, Could you possible meaure engine output by means of injector flow, ie, 440cc injectors at 100% duty cycle will flow enough fuel to make 88hp each at 11:1 AFR or something like that, so therefor these injectors at 100% will flow enough fuel to make 88hp x 6 = 528hp at the engine. but it is too hard to equate what it has at the wheels due to unknown loss through the drive train into heat. say for example we do loose around 25% that equals around 400rwhp
now i have tried to make sense of it all, and it does kinda work, just say that a gtr, does 450hp on a dyno at a proper ramp rate, but the standard 440cc injectors and standard AFM's are maxing out, now at the track the car actually does do 120mph or there abouts, does this mean that the car actually has 400rwhp, cause the injectors cant flow enough fuel to create over the 528hp, and the Afm's can only measure enough air to allow enough fuel to be burnt to create 528hp, factor in the given 25% loss it does equal around 400wrhp,
Now can this equation acutally be used, like does it work in your minds. And how much do you think is actually lost via heat in the drive train. 25%? so which would be right, the dyno or the calculations as they are reasonable similar?
Corret me if im wrong on anything, as thats what im hear to do is learn of others.
Cheers
Zenith
i think the most accurate way is a shootout mode dyno, such as a dyno dynamics. it calculates what ever power the car makes at the wheels and rounds it off to 25 deg ambient temp. so that when you compare your cars run in brisbane in summer at 40deg abmient temp to another skyline run in shootout mode in tassie in winter on a 10deg day the results are comparable as the dyno rounds it up from 10deg ambient to 25deg. it also factors in humidity and so forth. so the output you have is comprable to the one in tassie despite completely different ambient temp.
the problem still remains that a well looked after dyno is going to be somewhat more free rolling that a poorly maintained one... dyno's are good for competitions and comparisons on the same dyno (ir tuning purposes)... other than tha they dont hold much cred IMHO.
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
