I Have A Gtr Engine Wiring Loom No Cuts Or Breaks $250
Have 6 Gtr Standard Coil Packs $200 For The Set
Crank Angle Sensor $120
Gtst Throttle Position Sensor $30
Gtst Non Abs Brake Booster $50
I Have A Gtr Engine Computer That Is No Good. I Know People Use These To Make Up Harnesses. $20
Pm All Interest
https://www.sau.com.au/forums/topic/70282-r32-parts/
  • 2 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
