Hi all, basicly my mate just bought a 34Gtt. The thing runs smooth and nice only recently its start to play up a bit.
Everynow and then i'll put itself on a LIMP MODE, TCS off logo come on also with Engine light and another one which i forgot. Running like a pig, sound like a subaru LOL then i'll go away in 4,5 mins.
Anyone ever suffer this before? Just to help a bit the car has HKS front mount, HKS silent zorst all the way apart from that everything is standard.
Thanks
https://www.sau.com.au/forums/topic/70314-att-all-r34gtt-owners-please-help/
is it manual? and by limp mode do you mean you can't rev it past a certain RPM?
my car is doing the exact same thing, but i can rev it to whatever i want. 'TCS OFF' and 'SLIP' lights (means that traction control is temporarily unavailable) 'Engine' light is on too... haven't done diagnostic. I disconnected the -ve batter terminal overnight to reset the ECU, but that didn't help. I know exactly what you mean by the suby comment.
i think my car and your mates need to go do a Nissan dealer to run a diagnostic, see what the engine light is on for. Tell him/her to try the reset ECU thing, but if not.... take it to a dealer. Seems to be a fairly common problems with the GT-T's.
Yeah happened to me too for a while.
Hasn't done it for ages though.
The engine splutters a little and then comes good.
I just shut the car off, started it again and it was all good.
Running like a WRX is because of one of the coils packs not firing, it's the most frustrating sensation you can experience!!! I'm guessing Error 21
The coil packs in R34's are known for breaking if you look sideways at them
Never had this problem on my car, it's always had a nice amount of torque... has the car had a service recently? Checked the oil levels? fuel filter? how old are the spark plugs? just some things to check out.... I'd take it to a Nissan Dealer for a diagnostic too. Good luck!
FYI... you dont need to disconnect the battery overnight to reset the factory ECU... just disconnect, pump your brake pedal a few times until it's hard. Reconnect battery and start up, you will notice the reset has occurred.
It's your canister purge control valve, best bet would to be to contact Nissan NZ...I personally find Nissan AU to be useless. It will probably still end up being ex Japan though.
It looks repairable, if you don't want to though, try here [email protected]
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
