evo / gsr ???
Guest Emperor
Hello Japan Members :rofl:
I was wondering if any of you guys could give me some info on the differences between a evo and a gsr. Im currently on the market for a evo3, as the skyline isnt my style anymore.
I live in australia (hehe yes i know my location is in japan, i watch too much initial d :)) now i find it oh so hard to find any evo's as such all are the gsr model. Im going to go have alook at one this weekend, it is a 1994 Mitsubishi Lancer GSR S2.
Now before i go look at it, could someone give me some info of what would be needed to change it into a evo. From what i have found, the engine will need to be change to the 2L which i can get from a VR4, they do not have LSD so i will need both front and rear LSD, and im guessing the inside doesnt have all the fancy stuff like racing seats, and theres no bodykit. ohh and lastly the brakes im guessing are smaller/crapper. Is this about it?
Thanks Emperor
p.s i love the red style its very nice :(
ohh yeah would it be more worth while to save some cash and just wait and import a evo6+ from japan?
https://www.sau.com.au/forums/topic/70316-evo-gsr/
... and heres me thinking you're on crack because every Evo is either a GSR or an RS.... (or Evo VII GT-A or Evo IX GT)
Yes, what you said is basically correct as far as the Evo II is concerned, the engine being #1 and the bonnet/front fenders and other body kit parts being #2. Then the Recaro (?) interior I guess. But all that effort goes to waste when you see another guy whos done exactly the same thing previously go "nice fake Evo"...
I'd say wait and import an Evo V or VI if I were you.
Btw, wheres Irohazka? That spelling isn't Japanese, sounds more like Russian?
https://www.sau.com.au/forums/topic/70316-evo-gsr/#findComment-1298701
Wait until compliance is available on the EVO VII + EVO VIII. Much more car for the money, no dicking around with engine swaps, body work, diff changes, interior changes etc. These will be worth roughly $45k fully complied, on the road. Also don't foget that these are 2000+ model cars compared to a 1995 GSR, which you will spend $20000 purchasing + $15000 at least in modifications and you are still only have a tarted up GSR.
https://www.sau.com.au/forums/topic/70316-evo-gsr/#findComment-1298719
only evo 6 and up is elegible for import and im only aware of actual complaince plates being avaliable for the 7 at the moment .
there are a few earlier ones around domestically if you search hard . check the evo forums . they are all personal imports or rebirths under a loop hole in the vic road laws that existed a few years back , basically you got a domestic lancer gsr wreck , replaced it with an evo and the vic DOT gave you new chassie numbers and rego .
also popular is taking domestic gsr and replacing it with evo III running gear , engine , everything . its ok , except the real evos have different strengthened chassies and a few other things that cant be replicated and for collector value , well its a gsr with evo gear , its not a real evo .
45k for an evo7 imported it your up for it or keep searching for an earlier one , they do come up eventually
https://www.sau.com.au/forums/topic/70316-evo-gsr/#findComment-1298946
If you like i acan email a PDF about the evo 1 through to 3 giving you all details and how to tell a genuine and not a copy! Just remember to check with your insurance comany if they will insure, my brother almost bought a genuine evo 3 until we found out it was registered illegaly as an aussie model and couldnt be insured! He couldnt find any others so he settled on an evo2 to replace his aus GSR.
https://www.sau.com.au/forums/topic/70316-evo-gsr/#findComment-1324387
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
