What caused this to happen - cracked exhaust manifold??
Hey Guys,
After the really hot track day at Phillip Island my car was sounding like it had a gasket leak on the exhaust side. Stripped her down this week only to find a cracked & severely warped exhaust manifold :)
There was a 2 inch split/crack in cyl 3's manifold pipe and the metal was tinted blue suggesting some major heat.
Anyone know if the heat was the major factor in this -or- is it more likely that the crack had been developing over time and the heat just made it worse??
hahaha.........I would have thought so Nark but its not the only thing that would cause it. Maybe if a lot of people had this happen it could be an inherent fault in the design or something......All I know is it was an absolute b@stard of a thing to pull off the block 'cause it had warped sooooo much (and warped the heat shield 2). As for the shiney S/S one, if I had more time before the next track day I would have hunted an aftermarket one down but unfortunately I had to have the car back together ready for winton. Anyway managed to get my hands on a ported std item so should flow pretty well anyway.
Ash....thanks for the suggestion but my car has an a'market ecu etc etc and only got dyno'd recently so I know shes not running lean. Do have the req'd free flowing exhaust which helps but I'm thinking maybe when my manifold was match ported they could've shaved too much off in that area which led it to crack.
Did it snap and studs?
Looking at the designm they will always want to warp as the heat form all 6 cylinders is focussed int he centre.
But one thing i have noticed at a few Voc track days, you boys hok straight into full throttl work once leaving pit lane. I always do a lap of light throttle / med revs stuff to get a bit of heat into not old tyres, brakes, gearbox, diff etc, but also because i have a stainless steel manifold and i dont want to hit it with a bucket load of heat straight away.
So maybe a slighlty slower out lap may help reduce the heat shock/distortion?!?!?!
Troy.......Man it was a b@stard. Luckily it only snapped one bolt so not much drilling out to be done. B@stard part of it was that it was warped so that the studs were forced up against the edges of the holes in the manifold preventing it from being taken off the block. The diff was really apparent when I went to put the new one on....fitted straight up with the studs right in the centre of the holes.
You are right about the warping happening at the centre of the manifold as the crack was in the pipe off cyl 3 and once the manifold was off the block it had warped in a concave shape.
I usually do a slow lap outta the pits mainly putting heat into brakes etc - never thought about things like the exhaust manifold. Going against that is the fact that I'm running street rubber (more heat=less grip) so I tend to hit the gas straight after the out lap.
Will go easier for the first couple of laps at Winton and see how I go....
Where is the crack?
right neat the plate?And troy, en EX man will get most the heat-up done just idling before you hit the track man.
Yeah it'll rise somewhat more... but most if its already done.
Its the mechanical bits after the motor that need the warmup more-so
Ash.....Nah mate the crack was no where near the flange plates that connect to the block or the flange plate that connects to the turbo. The crack was close to where the pipe off cyl 3 mates into the common runner that lead to the turbo - but the crack actually ran along cyl3's exhuast pipe.
check the crappy attached pic......
I personally think it was some type of failure in the flux capacitor or possibly the Mr. Fusion......:D
Nah but really, could be simply a defect in manufacturing? What about timing and cams? Have you had diff cams put in? I'm not expert but you know how they play with timing (or is is exhaust cams) and it draws more heat away from the engine, perpahs it's caused the manifold to get super hot. Could be combination of both! If there was an impurity in the metal could be a probelm...
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
