Asking $600 delivered but offers considered. SOLD
This turbo has produced 220rwkw and was bought from one of the Rigoli workshops in Sydney in 1999. I was advised the turbo had been modified, but have no idea of the mods performed, just the turbo performance as it stands which has been compared favourably with a 2530.
It has been run at up to 14psi since this tune and has been consistent on the racetrack. It demonstrates no additional play since it was bought and has been cared for with oil changes every 5000km or before each track day and with sensible warm downs and turbo timer usage.
I will be replacing one of the dump pipe studs before sending due to the nut binding and fracturing the stud. Since this occurence I have used anti-seize to prevent any others binding.
Selling due to recent upgrade to twin turbo configuration.
DYNO Run piccie
Feel free to call during working hours on deleted or better yet email me (in my sig)
Terms are strictly payment before delivery.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
