Thanks mate. Can you do this before or after you start the car. I see 15 deg is the standard.
I'm not really sure which wire I need to put the timing light pulse detector bit on.
I have the manual and had a look. It said somewherenear the plug on te top of the engine..I read a few posts and I think they said that one should be 30 deg. I'll have to try it.
Cheers
When you set the timing make sure its up to full operating temp.
Disconnect the TPS with the car off, just to be safe.
Make sure the idle is @ approx 650rpm to set the timing.
Timing should be at 15deg btdc (middle mark)
Don't advance it to much over the factory, its already tuned for high octane jap fuel.
At the back of the head there is a white wire in a loop, just near the coil pack plastic connector. This is the wire to use for the timing light.
I've typically found that with alot of timing guns, this wire, allows the light to pick up all pulses, therfore not giving a light as it should from cylinder 1.
I usually have to use an old ignition lead between the coil and the spark plug to attach the timing light too.
Hey there - thanks for the reply. I don't really understand what you mean about an old lead between coil and spark plug. Do you have to pull the centre cover off to do this. All cars I've done this on have haed a distibutor i.e. no indiidual coil packs.
Thanks
Yeah connect your timing light clamp around the loop wire first and see it work succesfully.
If it doesn't work with your timing light, the only way you will get it to work, is remove the plastic coil cover (in between the cam covers), remove coil on cylinder one and use a normal spark plug lead (like on a dizzy car) to connect from the spark plug to the coil.
All this lead does is allow you to hook your timing light clamp around it, so it gets the correct signal to fire the timing light.
Hope that make sense?
It will make sense when you realise that stupid loop at the rear of the head doesn't work properly :)
Thanks a heap mate. So does the fitting on the coil have a similar fitting like it would coming off a distributor . I would have thought there would be an electical lead to the coil and the coil sits on the spark plut so the fitting on the bottom of the coil will only suit sitting on top of a sparky. Or is there a short lead from coil to sparky. I'll open the workshop manual maybe I'll understand better then :) instead of bugging you guys.
Thanks
Not really, i had to modify a lead to suit the application really, but now i have it, i can rip the coil off and use the lead to get my timing light working anytime i have too.
You will suss it all out im sure. With a bit of luck your light will work connected to the factory loop, but if it doesn't you know where to head.
Catchya...
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
