Hey guys,
I have done a search and their seems to be some info on fitting the oil gauge but it varies some people have said to fit it into the sump others have said that their is supposedly an area to put it near the oil filter.
Near the oil filter i would have thought would be more accurate and easier to setup but i cant find were the sensor is. Can anyone help out with advise/pictures of their setup.
any help would be appreciated
https://www.sau.com.au/forums/topic/70383-installing-autometer-oil-temp-gauge/
I have a DEFI oil temp gauge which I have hooked up. What i needed to hook it up was a "Sandwhich plate" which actually goes between the block and the oil filter, and allows you to input both oil temp and pressure sensors.
Im not too sure if your Autometer one came with the brass coated sensor, but my Defi did, and all I needed was the Sanwhich plate so I could mount it.
Basically the sandwhich plate has a hole to allow you to screw in the brass sensor. Once the sensor is in, your pretty much sweet to go
Hope this helps
Hope  this helps
hey dude yup that does help alot where abouts do you get the sandwhich plates from i will give autobarn, supercheap etc a call tomorrow hopefully they sell them.
any more info/pics would be great :)
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
