Blow off Valves - Apexi , Blitz, Greddy, HKS, Sard
  • Replies 52
Can you get the adaptor kits as well?? Im interested in the SSQV for my R34 but need the adaptor and plumb back kit too.
Checking on the prices of both the adaptor flanges and the plumbback kit (1421-FIT001) - it doesn't include vacuum hose.
But you can easily get a flange from Autobarn or other car parts store. If you do still want one, let me know.
/edit: I recommend the Greddy Type R though. Comes ready to plumbback without an additional adaptor.
put me down for a Greddy RS or S not sure yet, heard type r is pretty full on, for gtr's in single turbo etc init?? anyway, know of any/much diff in the other two? I think S is 37mm and rs 40mm and rs not as whistley and both can be plumbed back though rs nozzle maybe harder to get a tube on. can you confirm/ideas
S has a 37mm diameter, RS has a 40mm diameter, and R has a 47mm diameter recommended for vehicles over 300hp (stiff spring for 375hp)
Greddy RS is the newer design over the Type R and Type S. If you're not running anything crazy on your 180 I'd go the RS.
/edit: even though the type s is smaller it has the advantage of being able to be straight plumbacked no adapter... apparently greddy is making an adapter for the rs which isnt out yet but i honestly have no idea when this is going to be
Im interested
I got a fairly standard R33. But I'm changing pretty much every thing that is bolt on, ie turbo intercooler, exhaust, maybe even get it ported. What one will suite me becuase I have no idea what is what
Cheers
SirSkyline
Hey sirsky if depends on if you want to go plumback or not otherwise i mean they are all pretty similar... just diff sizes for the greddy... also depends on the sound you want...
Im interested
Cheers
SirSkyline
I'm interested in a Greddy Type RS... How hard is it to install one of these? I have an R32 Gts-t.
im installing mine on my r32 gtst and its as simple as bolting it on because i have a diamond shaped flange on my piping ... if you dont have one youd need a weld on flange which it would just bolt up to ... but any mechanic could isntall it for u
Much appreciated, let me know what prices the HKS stuff is available for. Depending on price, might take your offer and get a Type R, or even a RS.
Cheers.
found a couple of pics of the greddy ones to help me and others decide, they look like good units.
type r is chuncky compared looks industrial eh!
Do you reckon the blue nozzle on the rs is screw off? - and then another plumback adapter you mentioned screwed on? Do you reckon you could just get a pipe bit welded on even though may look a bit messy? Or even just stretch a hose over the nozzle and clamp? Kinda want the rs plumback :wassup:
Type R/Type S Compare
Type RS
Hey
Thanks for putting the pics up... it could either be take off the blue part or the they might just sell an adapter which slots into it similar to what hks do for the ssqv... haha i know what your saying about the rs becuase it probably is the best looking but welding is a lot of effort to go to for plumback i would just go for the type S
gor33: as soon as we get the numbers and everyone pays the deposit
I can now confirm that I can get the HKS ssqv recirc adapter it is an additional $25 Partno :1421-FIT001
HKS34R I Pmed you... pm me bak to confirm thanks
PM replied. Just a quick question though.
When you say recirc adaptor, you mean the parts required to make the BOV plumb back, and not an adaptor to fit the BOV onto the stock piping? Assuming this is correct, where can an adaptor be bought to mount the BOV on the standard RB25 piping?? We don't have an Autobarn here in Coffs, and the nearest performance shop in on the Gold Coast.
Any ideas??
Any ideas??
Reply yeah thats exactly what I meant... umm ill have a look around asee for you... im not too sure where else would stock the flanges
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
