By Celticsfan03 · Posted
I have new spark plugs, splitfire coil packs, and a new coil pack loom -
Dropped the 32 off to have a custom Half cage (3/4 cage?) fabricated will update once complete. Looking into harnesses now. I like the "yashio factory" ones purely because they are pink and look to meet all specs. But open to opinions
I want to say that Haltech can be used with ODBII tools nowadays. Kinda useful if you want your head unit to do other things as well, like maps, music, phone calls.. *and* digital gauges. Stock ECU does not use ODBII. I don't think a R34 is going to have any head unit that reads OEM ECU's to display.... the things the gauges already display. (boost, battery voltage, oil temperature, oil pressure)
Hmm. If it was S1, I would have suggested that you might have upset the coil igniter by working at that end of the engine. As is it, I would suggest that you might have upset the coil loom. You might have tired old wiring connectors that got moved. Not particularly likely though.
So, what you're really saying is that you should have bought an IC7 to put there?
