Matt, if you are so desperate for the dyno print I'll ask if he has it.
Geoffrey, you may also refer to my comment above :uh-huh: I wasn't desperate for the print but you'll recall I was not the only one asking why I didn't receive mine.
Anyway if the engine setup Steve's posted about is legit then good for him. Talk is cheap. We'll see who delivers the goods at Autosalon. :P
  • Replies 88
Anyway, if the engine setup Steve's posted about is legit then good for him. Talk is cheap. We'll see who delivers the goods at Autosalon. :P
i just got my new engine and very nice indeed what do people think how much power i would make at the rearwheels in a r33gtst put your info in and i give you the honest power figure? as it follows in mods
Rb26 stroked out to 2.8
hks crank
hks rods
hks pistons
N1 nismo cams
hks valves and springs
mild port and polished head
hks cam gears
n1 oil pump
n1 water pump
1000 cc injectors
100 mm throtlebodie
pair of 3240 hks turbos
and running it with motec m800 ecu
3 half in dump pipes into 3 inch nur spec r blitz sys
and nice new pair of fuel pumps and new fuel lines tobe put in
and nismo fuel reg
this it was ive got done and now have all built ?
as im yet to put it in the car i just want peoples thoughts of what power im going to put out in the rear wheels
"i want my penis to be this big... "
This is not really the same thing but considering i was buying an intercooler and piping off him and after story after story about not getting it and a month and a half later getting my money back i will agree he seems like a really nice guy but not sure if he talks a little bit of shit. Though he did speak to me about the engine saying it was true though i am yet to see any photo's
I've had some failed dealings with Steve.  Although he seems like a nice guy, things don't always go to plan.  Would be nice if someone came thorugh with a decent drag setup like this.
Best of luck with it.
A call would have been nice though.
Well if it is true, why would you need to ask the power output? I mean come on, i am not an engine builder, and thats not my engine which is getting built, and i could have a fair idea. No offence to anyone here, but if i was going to spend $10,000's on an engine, i wouldnt goto an online forum to find out what power it would be making unless i wanted to boast..... If the engine builder doesnt know then that would be a big concern for me..
Knowing steve for a little while he is the kind of person who talks soo much shit thats its not worth listening to.
I 2nd that.
Apexi TCW LS are in the photo, not 3240's... 3037S are heaps of power, no need to go 3240 on such a small 2.8ltr engine.
Maybe 3.1ltr's but not 2.8.
Steve your a clown
and i got the usual excuse for his car not being at the Autosalons. "Didnt have enough time"
lol. He lied about Buying David Lee's car. Lied about the mods to his car (which he was proven majorly wrong at HIS OWN dyno day, where he pulled jack shit kw).
I ask him for pictures on msn and then he goes completely silent. Someone dreams too much...
*sigh* if you guys read the original post (as punctuation-less as it is) steve was asking for your estimates for the power figure given the list of parts. He was then going to give you the actual figure once it was complete to see how your guesstimates compared.
I don't think he was asking for:
* critique of his choice of parts
* an analysis of his social behaviour
* an msn warrior's review of a fellow forum user
* resurfacing of personal vedettas against other members
* or a parrot's idea of what Chasers is building
this guy's asked a very specific question, and if you don't think it'll work, just say 0kw or don't reply at all. Most of the condescending attitude and useless 2c adding is why this section's gone to the dogs.
  • 6 months later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
