Ok so im planning my new install on my R32 GTS-t and just wanted the heads up on any trouble that anyone may of experincied in the past so i can plan ahead. Im planning on running a Pioneer 5750 HU with Pioneer components in the front doors replacing the stock speakers. I have another set of splits that im going to put into the rear parcell shelf. I have 2 MTX Thunders that i was thinking of using, can't decide if i want to run both in one box, 1 in a sealed box, 1 in a tube or two in the existing sub box, 2 in 1 tube or 2 in seprate tubes??? I plan on installing my new amp and hear that you either have to bypass the old amp or run new speaker cables, whatever is easiest i will do, but as im thinking of running the front splits of the head unit i dont see that as being a problem at all. Anyway just after anyones advice on the general install, how to and where to install and what you used for it in general?
Cheers GMB
https://www.sau.com.au/forums/topic/70445-r32-install/
U cant get anything bigger than a 6" speakers in the fron doors. ( in there stock hole anyway)
A little hard getting wires throught the file wall. but not 2 hard, nothing a coat hanger cant fix.
That's about all i have to say about problems I had on my install.
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1301208
as madtrang said the main problem is running cable throught the firewall, but its not that bad.
You'll need to make up some MDF mounting plates for the fronts. Just use the stock ones as a template.
I just ran new wires to all the speakers and bypassed the factory amp.
As for subs, it depends on how much boot space you can afford to lose. I need to fit a set of golf clubs in mine so I've got a small sealed box between the shock towers.
Head unit is pretty easy, just get the right wiring diagram off the net. I had to drill new mounting holes in the factory cradle to make my head unit sit flush with the a/c controls.
Let me know if you need any more help as I just finished my install last weekend.
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1301366
No prob's with getting cables through the fire wall, im used to doing the impossible, apprentice sparky by trade :headspin:
As for not getting anything bigger than 6" in the fronts isn't exactly right as we got a pair of 6X9's in my mates R32 no probs, but yes it did take modification of the existing speaker holes, nothing to drastic though. :)
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1302061
Where abouts you find the wiring diagram for the install and do you have a diagram for the amp bypass at all?
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1303788
Hmmm ive got 6 1/5" splits in my front doors, and they fit pretty good..
Wiring diagram? What for... Multi meter finds waht you need..
If you can avoid running the front splits off the head unit and amp them do that, becuase if your gonna have the subs in there, you want the power to your speakers to keep up with the bass. If anything, dont amp the rears, as they are just for fill.
Ive Installed my stereo in and out of my skyline and old cars heaps... so if you have any Questions Just PM me...:cheers: Good luck
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1304281
hmmm on my r32 i was able to fit 6 by 9s without any body mods just made up mdf backing.... only problem you would have is with clearance behind... depending on the mounting depth.... mine were like 78mm so they fitted up fine but i had to use 18mm and they cleared the windows but door trim wouldnt go on... if they were like half a cm smaller should have been able to fit them on problems... so it would depend on the size
but then again 6.5 inches speakers are way better
gotta do my install this wkend
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1314664
amp wiring can come through the drivers wheel well. there is a body grommet inside it that will allow a decent sized cable through it.
SO does that mean your running the cabling outside underneath the car?
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1316010
here is the link for the wiring diagram.
you don't need a diagram to bypass the stock amp, just run new wires from your head unit/amp to your speakers.
Is it worthe ripping out the old amp while im doing it?
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1318317
I didn't bother ripping out the old amp cos it wasn't in the way of anything I was doing. I guess you could take it out if you really wanter to save an extra kilo.
And with the cables, no don't run them under the car, just under the carpet. That grommet Chris Rogers is talking about ends up on the inside above the accelerator pedal.
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1318413
Oh ok, im with you. I'll ook into that, and i'll ahve to rip out the old amp and relocate the rear wiper assembly motor so i ahve enough room in there for my gear :wassup:
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1318492
don't bother with speakers in the rear if it's a GTS-t. They're not necessary and you'll save money.
The only reason i was going to put them in is cause i got em and there jsut sitting there but your right, you dont need them. Set of components up front with twin 10" MTX Thunders in the boot should do for now :headspin:
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1319365
Anyone got pics of the boot install with there sub box at all, after looking at the minimal room and height it limits your options and was wondering what everyone else had done to over come this? Post em up so i can get some idea's or just throw your ideas this way :rolleyes:
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1330907
personally, after listening to my system in the car after a week or so, I'd still greatly prefer a couple of speakers for rear, even if they are very basic and not high end ones. The sound appears to come much more "around" you, and I like that effect.
Just like at home I prefer 4 speakers powering my music at the one time.
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1331057
I was thinking the same thing pred and the way i see it i already have the speakers so i may as well throw them in there and make use of them!!!
https://www.sau.com.au/forums/topic/70445-r32-install/#findComment-1331553
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
