Hi all
Would like some opinions on if i can reach my goal of 200rwkws or not. My car (r33 rb25det) can from japan already with a heavy duty clutch and a t3/t4 turbo onboard. My budget is limited but i have the following mods and some in mind:
Clutch - installed
t3/t4 turbo - installed, but would only like to run around 10psi
k & n pod with cold air intake - installed
arc cooler - stock location but rated up to 400hp - 12cm think, 30cm high, 30cm wide. - installed
blitz bov - installed
turbosmart boost controller - installed
3inch exhaust - installed
3inch - 3.5inch dump pipe- to buy
jaycar safc - to buy
manifold has been hpc coated and wrapped
cam gears - to buy
Cheers
https://www.sau.com.au/forums/topic/70449-can-i-reach-my-goal/
Replace the SAFC with a PowerFC ($980) + Exhaust Cam Gear ($150) add in the installation plus a good tune ($600) and for ~$1700 you should see a nice round 200rwkw.
Note; you may need a new fuel pump, fuel reg and z32 AFM (~$800).
